Sovkiller
Proved that despite its huge size the CD3000 can be shoved down one's throat.
- Jul 31, 2002
While you say 650, you are talking of the Sennheiser HD650 right?
Are you familiar with Ultrasone headphones, and S-Logic???
Well if not, after you gave 200 hours to the phone, good to begin with, let me tell you that the burn in process does not end there...now you need to give 2 weeks, at least, to your brain to get used to them, OK?...
Also with no comparisons, as I have stated many many times before, even in this same thread, the S-logic effect takes a lot of time to get used to it, and you will need some time to get used to the natural presentation, you do not have in your other headphones. Also if you compare them back and forth to get the differences, as we usually see in all reviews, you will be reinforcing the unnatural presentation habit you are used to, time after time, and the result will be that you will never get used to the natural presentation they offer...it wil be more useful for you, to compare them with others once you are used to them, but not before...
An advice, take them for two weeks, and put the HD650 in a drawer for that time, after the two weeks, then listen both and tell me if you think the same way...
