miriddin
- Feb 18, 2010
don't use line out for connecting headphones. line out has an output impedance of 450 ohms in zishan, not suitable for phones; it's intended for connecting other devices, like amplifiers, which have way higher input impedance than phones.
line out power is about 0.14 Vrms when zishan is set to normal mode; if you set "turbo" (high gain) mode, line out gives you 1.8 Vrms, which is normal.
Thanks, but i already knew the line out function: i just tried to connect my 600 ohm DT880 to line out to establsh if the "missing left channel problem" was still there also with line out...
