Ivan TT
I recently modded my other DSD trying to achieve exactly that (my first DSD has x2 paralleled OPA1622 per channel, I estimate its output Z is around 3Ohm).the most "elegant" way to get a near 0 output impedance to drive my BAs in the best possible way
Stock DSD (assuming we are discussing AK4497 based one) in addition to output resistors has 22Ohm emitter resistors in the discrete transistor voltage follower circuit which is a little bit high (I usually see values of few Ohms (sometimes below 1Ohm actually). These are beneficial for preventing thermal-related effects, but 22ohms? Making output impedance 44Ohm effectively? Seriously?
I replaced those with 5.6Ohm 0805 resistors and bypassed output caps and resistors altogether, I don't hear as disturbing change in FR as with high Z output, but still evaluating this mod (including with multiple BA/low impedance IEMs). I also used bypass capacitors on these resistors (although in slightly non-convention way), this may improve output impedance further.
PS: currently listening to this mod using TF10, they are QUITE sensitive to high output Z becoming way to sizzly and lacking punch in LF, I am satisfied with how they sound right now: lows dig quite deep and there's good (but not overwhelming) sparkle in there too.
