The volume pots actually vary, my zishan has quite a stiff volume pot with no channel imbalance, but my mini A1 amp which uses the exact same volume pot has a looser volume pot with some slight imbalance at low volume, but nothing I would call a deal breaker, and anyway you can always lower the gain of zishan, then even if you get a pot with imbalance it will not affect anything as you will be using the middle range of the volume pot. But if you will be using an external amp most of the time then it makes sense to get the zishan version without volume pot just to be more compact. Also fyi, many Alps pot's I've used have also had imbalance at low volume.
Btw that amp your getting looks pretty nice, I want one
Also like I've said before, if your using an external amp the upgrades don't really matter much anymore. But even without an amp the zishan will power 300 ohm earbuds easily, if you want to ditch the external amp for a portable setup then the upgrades are worth getting, but for solo zishan I would get one with analog vol pot.
