Thanks to my friend,
@gadgetgod , I was able to listen to the
Symphonium Meteor today. The stock cable being a single-ended one, I had to pair it with a balanced cable to gets it to its full potential - so I brought out my
PW Audio SE Ultra Copper. The eartips I used was Moondrop spring tip M size.
First thing to note was the fit - thanks to the angled nozzle, it was rather deep, and that was the reason why the spring tip M size fit perfectly. Then I noticed how power-hungry it is! It truly needs some considerable power! But well, my DAP did have enough juice to provide, so no worries there.
Gears used - Shanling M7 Balanced Mid gain > PW Audio SE Ultra Copper > Symphonium Meteor
Test Tracks:
Whitney Houston - Tell Me No
Tool - Stinkfist
Leonard Cohen - Hallelujah
Estas Tonne - Strings Of A Bird (Acoustic) [Live]
The Meteor has a surprisingly V shaped sound that I definitely was not expecting given its graph - again a testament of how graphs does not necessarily portray how a gear sounds. Even from the beginning, I could feel how strongly it was tilted towards the bass and the treble - not necessarily a bad thing, just the way they wanted to tune it , I presume. Really put smile on ones face with the very fun bassy sound while simultaneously putting a lot of sparkles in the top end.
In fact, this may be one of those very few iems where the bass sound very VERY close to DD bass...and frankly, if I did not know that Meteor was an all BA iem, I would have readily believed it was an hybrid, with the DD handling the Low and the Mid, and BA for highs. Pretty bold, I know, it is not easy to sound like DD in the Low and Mid freqency with a BA, but the Meteor gets close, very very close.
The
Low end has a very significant amount of emphasis, and the subbass does reach quite deep and rumbles are very much powerful and gets quite physical! The midbass is not forsaken for the sake of the subbass, and packs a punch with about the same power - which is to say more than enough. Bass takes a front seat in the overall presentation, and it will grab you attention at the first chance it gets - which may or may not be delightful depending on preferences.
On the flip side, the bass does come off as slightly fat, and a bit slow - which ultimately affects the textures a bit. See, the subbass textures are pronounced, but the midbass notes, being a bit fat, a bit more extra meat on the bones, do sound slightly soft and blunted, smoothing the textures which does not help it. It is not bad, but having listened to other gears in a similar rice range - the difference does get immediately apparent.
Midrange is undeniably pushed back a bit since the Low is pushed forward, but that is not to say that it sounds drowned. Rather, it cuts clean through the bass.
Lower midrange sounds quite organic and full, with a very healthy note weight and body - which somehow feels carried forward from the midbass. Male vocals like Leonoard Cohen have a very nice organic and full base that sounds really satisfactory. Acoustic guitars sounds quite pleasing as well.
Upper midrange, on the other side, is slightly pulled back - which mainly affects the electric guitars, the female vocals, etc. It does get the overall sound rid off unpleasant sibilant peaks in this area, however, the slight lack of energy might not sit right with everyone. Not to say they sound drowned out - they still are quite cleanly heard, but they do not have that last amount of zing.
Following the path of the Low, the midrange notes are yet a bit on the smoother side. That, combined with the fact that the lower mid notes have quite a healthy amount of meat - makes them a bit blurred and soft, with textures taking the major hit - so it might not come out very detailed, but it still sounds quite organic and musical. The sticks and drums sound a bit soft and not as clean. Some female and male vocals do not show their inherent gritty nature. Electric guitars sound clean, but that bite and crunch might feel a bit missing, same for acoustic guitar as well. Due to the lack of energy, some female vocals fail to reach their full potential to sound ethereal - ending up sounding slightly muffled rather. All things considered, the midrange may sound nicely full and organic, but not very clean and transparent per my preference. Even so, Meteor does a splendid job of reproducing the background instruments in a somewhat nice way.
When it reaches the
High frequency, however, the game changes. The treble has a sudden burst of energy that pushes it a bit forward and makes the treble come forward, sound lovely and bright and quite crisp! Gone is that smooth nature - the treble notes are very well textured and feels really sparkly, with an even amount of energy in both lower and upper treble. The cymbals crash in a bright and spicy manner while decaying in a brilliant way. They do sit a bit forward in the stage. The notes do not sound overly thin, having enough body to sound natural. Overall quite surprisingly pleasing and in quite a contrast with the tuning of the rest of the spectrum. The spicy nature, in very very rare cases, might come off as slightly unnatural - but not much of a worry at all!
The
soundstage, well, here I do have some reservations. However many music I tried, in the end the soundstage rather felt a bit intimate to me. The imaging was fine, but the space between the notes was less. The Overall presentation is not so airy, even though the separation is notably good and clean. The height of the stage was quite limited, width was nice, so was the depth.
Now, let's compare this small 4BA powerhouse with a not-so-popular single DD contender - the 634EARS LOAK-T(CL). I know, you guys might be tired of me citing this iem over and over again, but once any of you gets the chance to hear it, I believe you will agree to whatever I have said till now to some extent.
The Meteor was paired with PW Audio Ultra Copper cable, and the LOAK-T(CL) was similarly paired with Effect Audio Ares S - so I would say the chain was pretty similar pricewise. Source was Shanling M7 balanced Mid gain.
LOAK-T(CL) sounds notably more detailed thoroughout the Low and Mid. The Low end is not as fat, sounds quite deep and tight, rumbles are quite deep and physical, and midbass slams with more power and yet sounds cleaner. Notes have more bite and textures pop out more easily.
Lower midrange has a nice body - slightly less in comparison, but more than enough to sound natural and organic. Again, notes have more bite here. Male vocals sound organic and more textured & detailed. Female vocals sound significantly more brilliant and emotional. The throatyness is quite easily apparent in the vocals. Guitars sound wonderful - more crunch, more details, more exciting - both acoustic and electric guitars alike. Midrange sounds noticeably cleaner and transparent.
Coming to treble, it has a similarly brilliant presentation, with slightly more note weight that makes it sound a bit more real and natural. The positioning of treble instruments is also not as forward as Meteor in the stage, but still somewhat forward nonetheless.
Soundstage of LOAK is significantly better than Meteor, hands down! The whole presentation sounds more open, with noticeably more height, slightly more width and may be similar depth. There is much more space between the notes, with a higher degree of transparency. It sounds much more dynamic than Meteor, which, to my ears, sounds a mix of smoothness and brilliance. Maybe this is what the term 'less coherent' means.
Frankly, I would say that Meteor is a rather nice iem. It is fun. The low and mid sound quite organic, full, and natural - very little to non BA timbre! The Treble is sparkling and airy. The overall presentation I would say tilted more towards musicality than detailed - but the details are not lost totally also. It is a very nice alternative set to have if one already has one that takes care of the craving of the detail. Although, it is not completely to my preference, and I do have other sets that I feel perform a bit better than this, but that is not to say its performance is subpar, rather noticeably good!
