The Takstar, Technical Pro, Gemini Greathon, CyberX, Qpad Thread
Jan 20, 2019 at 3:03 PM Post #4,621 of 4,701
Has anyone here tried the Takstar TS 450?
I own a pair. The TS 450 are extremely comfortable and light weight, with large pads. They are well built, with a solid click in the headband adjustment and a pretty thick cable, certainly for the price. The sound signature is enjoyable. Not super extended or detailed - just enjoyable. There was nothing I threw at them and they made it sound bad. I can't recommend them enough.
Jan 20, 2019 at 3:26 PM Post #4,622 of 4,701
TS 450 looks like a CAL-ripoff. Im tempted to pick up a pair just to compare them to each other.
Feb 11, 2019 at 3:26 PM Post #4,624 of 4,701
so these are just as good? old version will take a month and some and the new ones would be here like within a week...anybody got the v2?
You don't need to be confused. Before the Takstar Hi 2050's have been discontinued they released a V2.
They also changed/tweaked the specs.
Feb 11, 2019 at 4:10 PM Post #4,625 of 4,701
Have Takstar released a new version of the HI2050?
I always considered that headphone to be one of the best budget headphones I ever heard.
Feb 11, 2019 at 4:17 PM Post #4,626 of 4,701
^ that's why I want them
New Version• Frequency Response: 10Hz-25kHz • Sensitivity: 94dB±3dB at 1kHz • Driver Diameter: Ø53mm • Max.Input Power: 250mW • Rated Power: 100mW • Impedance: 28Ω±15% • Connector: stereo Ø3.5mm + Ø6.3mm gold plated • Cable: Ø4mm x 1.8m + 2.2m extension cable • Net Weight: 300g
older version • Frequency Response: 15Hz-25kHz • Sensitivity: 92dB±3dB • Driver Diameter: Ø53mm • Max.Input Power: 500mW • Rated Power: 250mW • Impedance: 60Ω • Connector: stereo Ø3.5mm + Ø6.3mm gold plated • Cable: Ø4mm x 2.2m + 1.8m extension cable • Net Weight: 325g
Feb 14, 2019 at 4:47 AM Post #4,633 of 4,701
Hi guys! Which one of takstar \ isk and others are best for 60-70$ ?
Tasktar hd2000
Superlux hd668b
Superlux hd660
isk hf2010
isk mdh9000
takstar pro82
JVC HA-S90BN
Which one is the best value for it's money?
