Apr 17, 2023 at 11:59 AM Post #21,811 of 25,221
Apr 17, 2023 at 1:20 PM Post #21,812 of 25,221
Small IEM should naturally fit snugly in the concha space
See photo:
https://service.shure.com/s/article/how-to-insert-and-wear-shure-se-earphones?language=en_US
If the tips are pushing the IEM body away from the ear then try swapping to narrower and/or shorter tips. The IEM body should not be "floating"
so the IEM fits into the concha part but the actual nozzle is angled so it’s not going deep into my canal. a straight nozzle would be about to go in deeper. is that a problem? i’m coming from the z1r which sits far inside the canal
Apr 17, 2023 at 2:30 PM Post #21,813 of 25,221
I see some shop listed the U4s as 11Ω and 107 dB/mw sensitivity but the 64Audio Main Site list it differently, 6Ω and 105 dB/mw sensitivity. Any idea which one is correct?
this is an error on our website. U4s is 11ohms 107db. we corrected it, thanks for bringing it up
64 Audio Stay updated on 64 Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/64audio https://twitter.com/64audio https://instagram.com/64audio https://www.64audio.com/ info@64audio.com
Apr 17, 2023 at 5:42 PM Post #21,814 of 25,221
my U12t arrived but can’t get a good seal with any of the tips - any recommendations? I use S Final Type E with my Z1R and S stock silicone tips with my monarch mkii
Acoustune AET06 M+ work the best for me! They don't restrict nozzle opening too.
Apr 18, 2023 at 12:57 PM Post #21,815 of 25,221
Sent out the impressions for my A12t... hoping for the best!
Apr 19, 2023 at 12:46 PM Post #21,818 of 25,221
Just ordered the U4s x iFi Go Pod bundle direct from 64 Audio. 🙏 praise the low-fi, mid-fi, and hi-fi gods to keep buyer’s remorse and FOMO far away from me.
it's a great sounding unit. We've tried every available version of this type of bluetooth adapter and this, by far, has the lowest noise and best headroom available.
Apr 19, 2023 at 2:33 PM Post #21,820 of 25,221
Can you also pair those with the Tia Trio.
Apr 19, 2023 at 2:44 PM Post #21,822 of 25,221
Yes you definitely can, we made sure to test them with all of our IEMs. They have enough headroom for our lowest sensitivity IEMs, low enough noise for our highest sensitivity IEMs, and can handle low loads like U18t and Nio. Only available as a bundle at the moment, but should be made available as a standalone unit once we get the go-ahead from the ifi folks.
Apr 19, 2023 at 2:48 PM Post #21,823 of 25,221
Does iFi plan to make IPX connectors available and pair with 64 Audio CIEMs?
Apr 19, 2023 at 2:50 PM Post #21,824 of 25,221
^^^ Seems me and Keane were literally thinking the same thing at the same time :) ^^^
Will the GoPod have an adapter for the 64Audio IPX connection? I see this statement on the ifi website "additional ear loops for Pentaconn, T2 and A2DC connections will be available. "
I wasn't sure if t2 and ipx are the same. Thanks
Apr 19, 2023 at 3:18 PM Post #21,825 of 25,221
Oh I didn’t check the iFi site. From my limited knowledge on cable connectors I think t2 and ipx are the same thing. Someone please correct me if I am wrong.
