Trance_Gott
I think U4s is a shocker for this price! U12t might be technically a bit better but fun goes to U4s. It's as much as fun as Trio but a touch smoother highs.
They have universals for even the N8 that they loaned. Not sure if they do that now, but I had loaners from them several years ago.Thanks for the suggestion! I’ve contacted them asking for the same advice, but did not inquire about loaners. That’s the downside of wanting ciems, no effective way to demo them.
What difference did you notice from the universal loaners vs. their ciems that you purchased? The insertion depth will have an impact on the sound we hear, and my fear is that the universal loaners won’t be an accurate representation of the customs.They have universals for even the N8 that they loaned. Not sure if they do that now, but I had loaners from them several years ago.
They were pretty similar. I did not have the loaners and CIEMs at the same time, but the overall sound signature is the same. Bass is a little better in the CIEM.What difference did you notice from the universal loaners vs. their ciems that you purchased? The insertion depth will have an impact on the sound we hear, and my fear is that the universal loaners won’t be an accurate representation of the customs.
Appreciate the insights! Very helpful!They were pretty similar. I did not have the loaners and CIEMs at the same time, but the overall sound signature is the same. Bass is a little better in the CIEM.
Well, you need to define fun, since MM2 is already a hoot with its big subbass and generally clear sound.Guys need some advice.
Im trying to find a fun set that will compliement my Monarch Mk2 and im interested in the u4s but have some questions. Maybe someone could help me.
Something laid back but fun would be great.
Ive had the Symphonium Meteor for a while but sold them due to the too callmed down overall signature but they were very close to my perfect tuning.
The Monarchs 2 were more exciting but even better controlled in the treble area (i found the Meteors very smooth across the spectrum but the last octavs in trebles could get to me in a slightly harsh way). The Monarch Mk2 was also a noticeable step up from the Meteor in technicalities, separation, timbre, vocals and of course DD bass.
Im aming at something close to the Meteor, with laid back tuning but with technicalites on a level of Monarch/u12t (well can be bit lower, dont mind if i loose 2-4% of microdetail).
I loved the u12t but found the Monarch more convincing in vocals, timbre and having deeper subbass rumble. The staging and imaging on the u12t were a treat tho.
Thanks in advance!
I have the Trios, which I use with Sedna Earfit Max tips. I also tried the spinfit cp 100+, which I like as well, but the fit can sometimes be finicky because the nozzles move slightly.my U12t arrived but can’t get a good seal with any of the tips - any recommendations? I use S Final Type E with my Z1R and S stock silicone tips with my monarch mkii
Final type E fit fine, but the 64a true fidelity foam tips are actually brilliant and the most comfortable frankly. This is what I use and ordered multiple from 64 audio. They’re much denser and better sonically than Dekoni foam for examplemy U12t arrived but can’t get a good seal with any of the tips - any recommendations? I use S Final Type E with my Z1R and S stock silicone tips with my monarch mkii
I had the same issue. Strongly recommend the SednaEarfit Max... I made a post about it with a photo here:my U12t arrived but can’t get a good seal with any of the tips - any recommendations? I use S Final Type E with my Z1R and S stock silicone tips with my monarch mkii
For 64 IEMs I find that the Spinfit W1 work really well for fit and sound signature. Though they are a little spendy and can be hard to find at times.my U12t arrived but can’t get a good seal with any of the tips - any recommendations? I use S Final Type E with my Z1R and S stock silicone tips with my monarch mkii
