Hanesu
Anyone compared the u4s to the Fir Audio VxV? I`d be really interested in this comparison!
Stay updated on 64 Audio at their sponsor profile on Head-Fi.
This cable is so so much better then the stock and cost not much.
Very interesting IEM my review will come...
What is that dac(?) that you have the U4s connected to?So fun. And I love the color scheme. After extensive tip rolling (25+), Included L foam tip w/ M12 module strike a balance for me.
I gave up all my portable gear not too long ago, but I guess I'm back in
https://www.questyle.com/language/en/m-15/What is that dac(?) that you have the U4s connected to?
Questyle M15. Wonderful little dongle DAC/AMP.What is that dac(?) that you have the U4s connected to?
I would think the N8 will be warmer than you want. Have you contacted 64 Audio to see if you can get loaners to try? They used to do that for a refundable deposit.Seeking some advice…
My current daily IEM is a pair of 1964 Ears V3 CIEMs that’s 10 years old and paired with a set of Effect Audio Eros S cable. Source is a Sony WM1AM2 playing mostly flac files.
I’m looking to upgrade, but can’t decide if I should go with the A6t, N8, or A12t. My preferred sound signature is neutral to slightly warm. I do like some impact in the bass and details on the low end, but I am far from being a basshead. Details in the mids are also important to me.
Also looking at buying a pair of Sennheiser IE600 as my go-to universal IEMs, but definitely want a new set of CIEMs. Any helpful advice is much appreciated.
Thanks for the suggestion! I’ve contacted them asking for the same advice, but did not inquire about loaners. That’s the downside of wanting ciems, no effective way to demo them.I would think the N8 will be warmer than you want. Have you contacted 64 Audio to see if you can get loaners to try? They used to do that for a refundable deposit.
