And just got my DX300 and really liking it to be honestOh my gosh, I LOVE AGNES OBEL! And U12t brings her voice to life
There is a Amp13 to be launched with NuTube soon
Gonna get one
For me it comes down to all day comfort and fatigue. I use my IEMs at work all day, so I need something that is comfortable and not fatiguing. My 64 Audio Trios are the best of all my IEMs in that regard. Whether or not the APEX feature helps reduce my tinnitus is up in the air, but I can wear them all day and I'll forget I have them in my ears. I typically listen at low volumes also.I am curious, does the APEX technology in fact help those with tinnitus to have an easier (less flare ups) listening experience than without it? I've been searching and reading threads here, there were some mixed reviews, but involving very few people and this was several years ago already. Any new thoughts from anyone about this? (I'm considering the U12t). Thanks.
I don’t use comply anymore as I found them a bit stiff and difficult to put in, and I found them a little bit uncomfortable. For my Trio I use the orange Symbio F foams. I find them soft enough to put into the ears and I don’t get any bulge or stress on the ear canals. I can easily listen to the Trio for hours without any fatigue. I obviously can’t say whether this would work for you or not but it’s something to consider perhaps.Hi everyone. So, today I tried out the U12t phones at the famous e-earphone store in Tokyo, using them with my Shanling M3X player. Wow! They sound great. I understand the fuss about them.
HOWEVER... there was a problem. I was having trouble getting a good seal with my right ear. I realized that my right ear canal must be narrower, so literally it just wouldnt go in very far, the tube seemed too thick for it. I am a long time Etymotics user, and this is never a problem, the stem seems to be significantly narrower, so they do fit. I'm a foamies guy (that doesn't quite right...), so in the store, I was able to try the Comply small, medium, and large. Actually, with the large, I could kind of get a seal in my right ear. I suppose this might be because it was so large that it was covering the canal from the outside? I don't know. It wasn't ideal, but it did work. SO my question to you all is... if you have a similar issue with 1 or both canals being too narrow for these phones, and you use foams, are you able to make it work and get a good seal? How? I actually don't like the comply, I never have. I much, much prefer the Etymotic brand ones. They're not so squishy and soft, they're easier to roll before you put them in and get a nice narrow tube to stick in your ear that keeps its shape for a little while, and then it really fills out. I don't know... is there another foam brand I might have better luck with, maybe one more similar to the Etymotic brand foam, or...? Or basically, is there no real solution if the ear canal is a bit too narrow for the stem? I did actually do alright with the large comply, there was a seal I think, but... I don't know. Anyway, thoughts? I want to see if I can make this work. Thanks.
And @Rodmunch and everyone above, thank you for your replies regarding my other question. Now I really need to figure out the size and seal issue.
In my experience, the Comply SmartCore Sport Pro Premium tips have worked exceptionally well because they’re specifically designed to prevent slipping in sport/exercise applications-- they use a foam material that is less dense so they are more comfortable and have less impact on the sound than the standard Comply 500 series. @shabta also recently tracked down the Sport Pro tips and reported they solved his fit woes. Silicone is generally a less than ideal material for ear tips and especially for users with small ear canals.Hi everyone. So, today I tried out the U12t phones at the famous e-earphone store in Tokyo, using them with my Shanling M3X player. Wow! They sound great. I understand the fuss about them.
HOWEVER... there was a problem. I was having trouble getting a good seal with my right ear. I realized that my right ear canal must be narrower, so literally it just wouldnt go in very far, the tube seemed too thick for it. I am a long time Etymotics user, and this is never a problem, the stem seems to be significantly narrower, so they do fit. I'm a foamies guy (that doesn't sound quite right...), so in the store, I was able to try the Comply small, medium, and large. Actually, with the large, I could kind of get a seal in my right ear. I suppose this might be because it was so large that it was covering the canal from the outside? I don't know. It wasn't ideal, but it did work. SO my question to you all is... if you have a similar issue with 1 or both canals being too narrow for these phones, and you use foams, are you able to make it work and get a good seal? How? I actually don't like the comply, I never have. I much, much prefer the Etymotic brand ones. They're not so squishy and soft, they're easier to roll before you put them in and get a nice narrow tube to stick in your ear that keeps its shape for a little while, and then it really fills out. I don't know... is there another foam brand I might have better luck with, maybe one more similar to the Etymotic brand foam, or...? Or basically, is there no real solution if the ear canal is a bit too narrow for the stem? I did actually do alright with the large comply, there was a seal I think, but... I don't know. Anyway, thoughts? I want to see if I can make this work. Thanks.
Yes, you'll need the Sx-500 version. With respect to isolation, it depends on the proper fit of the tip and 64 Audio Apex module used but you likely will not achieve the high level of isolation as Etymōtic in ear monitors. That said, I have owned Etymōtic ER4 monitors since 1993 and think very highly of them especially for users with small ear canals.For these Complys, and also the Symbios, do I need to worry about bore size?... Also, I have to say,. even if I do get a good fit I can tell that it won't be possible with these phones to get the isolation that Etymotics provide. It's no small thing on a noisy train. Thats said I guess some tip experimentation is in order.
Does anyone know if you can still track the production steps of your CIEMs? And how long it took until production began from date of purchase if you didn't do the rush build? Getting antsy and thinking maybe I should've done the 7-day build on my A3T
Yes, those are the Symbio F.Thanks!! So I have been searching and actually can;t find the info, do you happen to know the bore size for these phones? Anyway, are these the orange foams? https://www.amazon.com/SYMBIO-Memory-Universal-Premium-Earbuds/dp/B08R94MCKF?th=1
I too have found the Comply SmartCore Sport Pros excellent woth the U12T, and use Westone OtoEase lubricant to help reduce friction-related soreness when inserting them- though it is important not to use too much as that makes the foams slip out of place/seal. I also have different sized ear canals (R larger than L) and have of late alternatively been using SpintFit CP 145 large silicones which fortunately work pretty well, but so do the Azla Sedna Xelastics (large). While both of them more block the external canal than fit into it, I find that the quality of bass is a bit tighter and bass decay is less artificially prolonged than with the foams, and treble extension, quantity and technicalities are more preserved than with foams. But sometimes I just want to feel the bass slam rattle my brains and the foams are great for this.In my experience, the Comply SmartCore Sport Pro Premium tips have worked exceptionally well because they’re specifically designed to prevent slipping in sport/exercise applications-- they use a foam material that is less dense so they are more comfortable and have less impact on the sound than the standard Comply 500 series. @shabta also recently tracked down the Sport Pro tips and reported they solved his fit woes. Silicone is generally a less than ideal material for ear tips and especially for users with small ear canals.
Agreed. The Comply SmartCore Sport Pro Premium tips are good for users with small or irregular ear canal shapes. In addition to the shape of the outer memory foam, their extremely thin, flexible core allows the tip to be compressed to a very small overall diameter. By comparison, SpinFit and AZLA tips have rigid, thick cores and that becomes the limiting factor in the overall tip diameter/compressibility and poor fit for users with small ear canals.I too have found the Comply SmartCore Sport Pros excellent woth the U12T, and use Westone OtoEase lubricant to help reduce friction-related soreness when inserting them- though it is important not to use too much as that makes the foams slip out of place/seal. I also have different sized ear canals (R larger than L) and have of late alternatively been using SpintFit CP 145 large silicones which fortunately work pretty well, but so do the Azla Sedna Xelastics (large). While both of them more block the external canal than fit into it, I find that the quality of bass is a bit tighter and bass decay is less artificially prolonged than with the foams, and treble extension, quantity and technicalities are more preserved than with foams. But sometimes I just want to feel the bass slam rattle my brains and the foams are great for this.
Having said all this, I am using the same approach with the same tips with EE Legend X and Thieaudio Monarch Mk2 and receive the same general effect. The particular qualities of each IEM vary of course, but live found this tip approach works across these quite different t IEMs.
RIP Andy FletcherAs most probably know Andy passed away yesterday
Now Depeche Mode always was and still is one if not my most favorite band
See them live last time in Antwerp, Belgium
Hell of a concert
So if you got time listen to Home it's on the Ultra album
Have a great weekend my friends ...
Actually that's very useful, thanks. Looking at that, I'm thinking that actually the Trio might be a better fit. I also found a pic of the Nio and that also looks like a promising candidate, maybe... https://headfonics.com/wp-content/uploads/2020/11/DSCF4254-1.jpg Would be great to see a comparison of all of their lineup but doesn't seem like that exists. I wonder if any of the 64 audio phones have a reputation for being a better fit for those with narrower ear canals? Personally, I want to go as etymotic-like as possible, for both stability and isolation, long thin stem that can be inserted more deeply.Yes, those are the Symbio F.
With regards to the bore size I found an interesting post that will show you the relative size of the nozzles for U12t and Trio. I hope it’s useful.
https://www.head-fi.org/threads/the...ia-technologies.826606/page-913#post-15875707
