Here is my setup
just as a transport? why not just a regular cellphone? or maybe the computer in the background?
Here is my setup
Here is my setup
Remember to buy it from Alibaba. It does not leave volume active. I preferred audio quality with USB-C to Micro USB output than USB-C to Audio output to Mojo (Shanling cable I think).What USB cable are you using to connect the Mojo and the R3 (sorry if you have mentioned this already somewhere)... and does it leave the volume active on the R3?
Do you have a link for this otg cable?Remember to buy it from Alibaba. It does not leave volume active. I preferred audio quality with USB-C to Micro USB output than USB-C to Audio output to Mojo (Shanling cable I think).
I don't think all Masters are MQA encoded. Some of mine show MQA when playing and other show flac. I think this was discussed awhile back in the thread.And now the option to connect the R3 is gone. And even though I select masters on my R3 they play as flac. I thought it would play MQA.
Does anyone know what the Shanling L2 cable is doing differently to bypass the internal volume control on the R3 when connecting an amp/dac (especially with the mojo)?
I am trying to connect my iDSD nano black label to the R3 and have tried the Apple OTG cable and the iFi OTG cable and both leave the volume active on the R3 as well as the low/high gain settings.
To my ears it sounds much better in high gain but then there is little room to adjust the volume on the nano black label because even with iEMatch it is too loud as soon as you touch the volume.
output r3, do you mean the maximum volume to connect it to the mojo?I have no specific information but I think it's safe to assume that the R3 has 2 different digital-out pins connected to the USB-C.
What is not clear is whether the digital signal is exactly the same when EQ is switched off and volume is set to 100%.
With early FW there seemed to be a difference between the Shanling L2 and the HiBy coax cable output, but I could not hear a difference after one of the updates which came in early summer.
I did a quick test with the Mojo, and yes, SQ is better when R3 output is set to 100%. Reducing the R3's output to 30% and increasing gain on the Mojo leads to a more compressed, less airy sound.
