I had to fix the number of 2.4GHz wifi SSID, I mean, I changed Auto to channel number 6 that at that time was almost free inside my neighbour battle.
Wifi worked and Tidal as well
It's just strange because Wifi and Tidal both work. I can connect to my Tidal account and view my playlists, but I get the "playback failed' error when trying to play anything.
I took my R3 to the Berkshires this past week and came home to find the balanced cables for my Creative Aurvanas had arrived. Wow! I'm very pleased with the sound. Wifi is working OK, AND Bluetooth too. So I'm very happy.
That being said, I haven't tried DAC mode and may not try it. I don't use Tidal and not even sure what Hibylink is. I have hi-res files and 44/16 ripped files on a 2000GB card.
I tend to use IEMs with this player and over-ear planars with the R6 through a DAC and various amplifiers.
So been doing A Lot Of listening to my R3 mostly with my Denon AH-D7200 less with my Focal Elear & my Audioquest NightHawks & for my use am really liking it esp more so with the Denon’s.
As with you many if not most of the issues plaguing others have not affected me or are not of interest even before the latest fw upgrade.
Have you listened with your Elex & Aeons, what do you think of the pairings?
I have exactly the same on any network. Have tried DNS settings and nothing solves the issue. I am at a loss how some have it work and I always have playback failed...
Can you tell me more about your flash drive and how it connects to your R3? Does it just plug in directly to your USB C? Does it have to be powered externally?
Hi I have the issue playback failed. I tried setting my router to DNS 8.8.8.8 and then tried entering same DNS on R3. Dis not work. Can you share what you did that works?
Thank you!
Thank you!
I also tried different security settings on router and it’s not that. I tried setting a dedicated channel and no dice. I have multiple routers and Tidal will not play on any. Not sure what to do from here. Reported to Hiby that firmware did not fix issue but no reply as yet. Will post whatever I get back from them.
So I can't figure out why the bass response on this unit is so darned weak.
I am starting to wonder if the impedance that was planned for is not what we are actually getting. In other words, maybe the poor bass response is in fact an impedance issue.
Has anybody tested the actual impedance of this unit?
I know one or two others have mentioned poor bass response, and others say its great.
I have problems with the FLC8S in balanced, and through my car through the regular 3.5mm jack fed to auxiliary out.
I have no problems with either scenario with my Cayin N5II, and the 3.5 output of my Shalings is just fine with regard to bass in both IEM and car scenarios.
No weak bass response here at all.
My R3 has an elevated, thumpy bass, treble that is pushed to the detailed, almost sharp side and mids somwhere in between, hard to characterize.
Cayin N3 sounds flatter/more neutral a bit more natural and clear, but not as clean as the R3.
Mojo sounds much more liquid, clear, clean and smooth, free flowing, with a deeeep soundstage.
But the R3 has the most pronounced bass of those 3.
I actually would like to have a more neutral presentation, keep the clean sound, but combine it with the neutral and natural balance of Cayin N3.
(listening with NightOwl and Pinnacle P1 IEM)
@Wickham The flash drive plugs directly into the USB C . I use an adapter from USB A to USB C. Here is the drive.You can purchase on Amazon. Seagate Expansion 1TB Portable External Hard Drive USB 3.0 (STEA1000400)
