Dec 22, 2015 at 6:55 AM Post #15,436 of 20,146
I just really love their soup-bowl styling, the rails that the phones actually are mounted to are nearly comically thick, their rather ostentatious. I'm a big aesthetics guy when it comes to over ears, if I want my sound to be right on I go IEM. I guess I'm a bit of a diva.
Dec 22, 2015 at 7:12 AM Post #15,437 of 20,146
had this on my head for about 10mins just now....
does the name TELEFUNKEN rings a bell?
this can is known as the TELEFUNKEN HANCOCK.
http://www.amazon.com/Telefunken-HANCOCK-Over-Ear-Isolating-Headphones/dp/B00ZGF4V90
50mmdrivers...slurps..very very light weight..headband is some aluminium or flexsteel strip?
shallow velorpads...very very light clamp on the head, very very poor isolation...
very clean thin treble,  lean mids...
 "planar" like bass, the drivers trying to latch on to something to generate the bassheft
but to no avail..lol. ( think problem is i am armed with only a Note1 :P )
But i suspect,
this would generate some clean magic with classical pieces when put on a tube amp...
u sitting on an armchair on a quiet night.
my short impression n imagination.
ps: just found out, this can is supposed to be SEMI open...
so that explains the poor isolation n light clamp design.
Dec 22, 2015 at 7:25 AM Post #15,438 of 20,146
But i suspect,
:P
Nice, but I like these more.
Dec 22, 2015 at 7:40 AM Post #15,439 of 20,146
http://www.head-fi.org/products/telefunken-elektroakustik-audion/reviews/14110#comments-title
this pair is bulletproofboxed  ..the Audion.
Dec 22, 2015 at 7:58 AM Post #15,440 of 20,146
Why bulletproof, are you on the wanted list - I think I might be on one of those lists very soon!
Dec 22, 2015 at 3:11 PM Post #15,449 of 20,146
Yepp, Monk wins!
   I believe they used to throw them back into the sea before they became trendy.
Dec 22, 2015 at 3:18 PM Post #15,450 of 20,146
Thanks Peter, that is good to know, I was wondering why they were the same price, I wonder with the T40iii would you have to drill holes or just remove some tape to make them ported.
Tbh I'm not sure about how the vents are closed (I'm only familiar with the T50RP MKii) but I'd go for the open version because it will most likely be easier to close the vent than to open it. That is if I was supposed to mod them....
