The iBasso D12, dual dacs . images . new Sysconcept optical cable . . Topkit by HiFlight. .
Aug 17, 2011 at 11:47 PM Post #466 of 606
Do you feel you want more gain or is it something else?
I have a D10 and it didn't really push them loudly enough for me to achieve decent headroom.
Aug 18, 2011 at 12:22 AM Post #467 of 606
K701's require a lot of current in my opinion so even if they are low impedance they still need good levels of power. Perhaps it is an excuse to try a PB2!
Aug 18, 2011 at 8:01 PM Post #468 of 606
Since the Q701's have an impedance of 60 ohms I would guess that the D12 is running out of current.
A higher authority (Top Flight) advised me to try using LMH6643 from the Op Amp rolling kit, this Op Amp can output up to 75 milliAmps.
In addition it has a very low output impedance.
I'll try the LMH6643 Op Amps out when I get some free time and report back..............
Sep 5, 2011 at 9:49 AM Post #469 of 606
OK,
I pulled all the op amps out and replaced the buffers with dummy buffers.
First I tried using the LMH6643 in the centre L/R . Waddaya know, D12 has no problem driving my Q701s, good tight punchy bass with an open middle and treble.
Then I replaced the LMH6643 with an AD8532, a bit noisier which was fixed by reducing gain to +3 dB and turning the volume up a bit. So far I'm still trying to figure what the difference is, but the AD8532 does something to the midrange.
My theory is that the Q701s need a lot of current (both the op amps I swapped in can supply a fair amount of current into the load).
More later.
Sep 5, 2011 at 10:05 AM Post #470 of 606
OK,
My theory is that the Q701s need a lot of current ( both the op amps I swapped in can supply a fair amount of current into the load.
More later.
Chris...
If you need still more output current from your D12, you might also try the AD8397 in L/R.   As it has built-in buffers, it is best to use it with the bypass (dummy) buffers.   IMO, it does a better job in the L/R position than the AD8532 considering overall tonal balance.   SQ is similar to that of the LMH6643 but with more muscle.
Sep 5, 2011 at 5:40 PM Post #471 of 606
Hi Topflight,
I prefer the LMH6643 sound, but what I am really looking for is more clarity and transparency.
I very rarely turn the volume past 12 o'clock.
regards, Chris
Sep 5, 2011 at 7:47 PM Post #472 of 606
Hi Topflight,
regards, Chris
LT1678 will do that.  Quite detailed and transparent.
Sep 6, 2011 at 9:23 PM Post #473 of 606
Unfortunately they don't source/sink a lot of current, can you recommend a good buffer? Any idea what buffer is shipped with the D12?
Sep 6, 2011 at 10:43 PM Post #474 of 606
If you seldom go above the 12:00 position with your volume control, I think the LT1678 would still work well with bypassed buffers and give you the SQ that you are looking for.  I can tell very little difference between it and other L/R opamps with buffers as far as driving ability.  I really like the sound of the LT1678 and often use it as the optional opamp for several Topkits.   You might try it with the LMH6643 as buffers.   Should be a very good pairing.
Sep 11, 2011 at 6:18 PM Post #475 of 606
What would you guys recommend as a good starting point configuration for the following headphones
Westone 3, Grado, ER4S
TIA
Sep 11, 2011 at 8:14 PM Post #476 of 606
TIA
This was what I got from my HiFlight Topkit For my Grado 325is'.  I can put up the ones for my um3x if you like.  I just have to open my D12 up.
Sep 13, 2011 at 4:29 AM Post #478 of 606
Using the LOD from the iphone uses the phone's DAC, which then passes the analog signal into the D4/D12 for amplification. The dac in the D4/D12 is not used; you can only use it via usb/optical/coax.
Sep 13, 2011 at 3:02 PM Post #479 of 606
Oh I didn't know that, thank you. I always thought the LOD also bypassed the internal DAC.
Sep 14, 2011 at 12:25 PM Post #480 of 606
I've tried using the LOD on my iPod to D12 Aux In............I wasn't too impressed, I thought the bass was too loose.
I normally use a Wadia 170i with my iPod, I use the digital output on the Wadia to the D12 spdif.
Unfrotunately I can't walk down the street with it, but it's nice for sitting outside on my deck. LOL
