The HIBY R3 I- Removed info on Earlier R3 Versions - Added R3 II Specifications
Aug 5, 2022 at 10:33 AM Post #6,511 of 6,951
Thanks, good to know. Not a deal breaker as I would only use it for offline stuff.
I use the DLNA renderer function quite a bit to stream locally from my NAS music library... I have also used AirPlay a few times... So the R3 Pro is a better fit (for me).
Aug 11, 2022 at 5:51 PM Post #6,514 of 6,951
Aug 11, 2022 at 6:18 PM Post #6,515 of 6,951
-- the MSEB is based on a parametric EQ:
1 -- Overall Temperature is a tilt of the whole FR line towards treble (cool) or bass (warm) Think of it as keeping the FR a straight line on a dB to log frequency plot but turning it clockwise or anticlockwise.
2 -- Bass extension is a critically damped parametric low shelf at 70Hz and below
The rest are parametric point EQs of varying Q at
3 -- Bass texture 100Hz (medium)
4 -- Note thickness 200Hz (wide)
5 -- Vocals 650Hz (very wide)
6 -- Female overtones 3kHz (tight)
7 -- Sibilance LF 5.8kHz (medium)
8 -- Sibilance HF 9.2kHz (medium)
9 -- Impulse response 7.5kHz (very wide)
10 -- Air is a critically damped parametric high shelf with corner frequency at 10kHz (which should then slope all the way to 20kHz)
The bands are in general wide enough that they blend into and affect each other evenly for you to be able to craft a wide variety of shapes.
Chosen to best capture the corresponding description, rather than taking a regular EQ with evenly spaced out bands of equal Q and trying to describe each band.
Aug 26, 2022 at 10:35 PM Post #6,518 of 6,951
hi guys I have a problem with my hiby r3 pro, when I try to connect it with Bluetooth with my Android car stereo, the stereo doesn’t recognise it and it will disconnected from the player. Anyone can help me? Thanks
Sep 29, 2022 at 4:42 PM Post #6,520 of 6,951
Hi i tried the EQ setting for the first time and it didn’t work i first toggled the key then moved the dot around but no change at all !
power cycle it by holding power button down for 10 seconds
update firmware
reset all settings
try different songs
try presets
try mseb
Sep 29, 2022 at 6:51 PM Post #6,521 of 6,951
It seems that Hiby is getting ready to release the R3 Pro S 2022. This will have the updated ES9219C DAC and a slightly new look. Unsure if there are any other updates.
Sep 29, 2022 at 7:44 PM Post #6,522 of 6,951
how long does battery last for music playback on r3?
because it has a battery double size of my ap80 and ap80 lasts me 12hrs
Sep 29, 2022 at 7:57 PM Post #6,523 of 6,951
Are you listening balanced or single-ended or a mix of both to get 12 hrs?
Sep 29, 2022 at 8:02 PM Post #6,524 of 6,951
