CactusPete23
Use a data only USB cable. That way no power can be sent.Thanks for suggestion. Tried it already but with no success (
OOPS, My Mistake. I have a "data only" USB Micro cable. But it seems there are none available for USB-C... Perhaps USB-C design does not allow Data Only cables? Sorry, I'm not a cable expert.Never heard about such a cables. Do you have a link for it?
I am curious about the Qobuz app on the R3 Pro — does it have both a parametric equalizer and MSEB? If one uses the R3 as transport for a USB-connected external DAC, can you still use the EQ/MSEB settings or do they only affect the sound from the internal DAC?
What USB does your DAP have? Micro B or C? if its micro B then there are USB cables available that prevent the DAP charging the connected device.Thanks for suggestion. Tried it already but with no success (
Cheaper:I need exactly the same cable, but are you sure that it made specifically with the feature of do not charging the connected DAP? Cause I don't see see any statement about it
Here we have statement in the description about the "non charging" feature. Looks like a good way out to try. Thank you!
Just tried some Google searches. Glad to help out. Also found this one (faster shipping):
https://www.amazon.com/Fiio-CL06-Type-Micro-Cable/dp/B07DLQ2XYZ/ref=sr_1_1?crid=2XX7LESHN3RES&dchild=1&keywords=fiio+cl06&qid=1616067040&sprefix=fiio+cl,aps,173&sr=8-1
Obviously not tested by me on R3 Pro. I actually have this cable for my FiiO Q5s.
Obviously not tested by me on R3 Pro. I actually have this cable for my FiiO Q5s so may be opposite of what you need.
I'm afraid that this not going to work. In the description it says that it's not charging the device because of OTG from the both ends.
I have OTG cable for USB type B and OTG cable for micro USB + I have USB type A cable from both sides. So I conected 2 OTG cables with USB type A cable and then connected DAP with R3 - still charging.
Jus called my local technician friend and he told me that he used to deal with the similar case before and the solution was to add resistor to the charging conductor of the cable. The goal is to find the lowest possible resistor, which letting the both devices see each other, but in the same time minimized discharging to the close to zero level. He said that its no possible to stop discharging completely as power exchange is one of the requirements of such a connection, but it's possible to minimize it a lot, so it's not going to bother as an issue.
Thank you a lot for your kindest offer! I don't think as it's going to work in my case, due to the test I described above.
But it seems that I found a solution, which I also described in a previous post.
Anyway, really appreciated for you kindest help and amazing effort!
I am testing now. R3 Pro USB-C out => FiiO CL06 cable => Fiio Q5s micro-usb in. The Q5s does not indicate charging.
