The HIBY R3 I- Removed info on Earlier R3 Versions - Added R3 II Specifications
Sep 19, 2018 at 5:18 AM Post #4,367 of 6,951
Sep 19, 2018 at 8:21 AM Post #4,368 of 6,951
OTA update worked, but where do you set the theme in system settings??
I find the "Color Theme" setting, but all that does is change the UI color.
confused...
Sep 19, 2018 at 8:31 AM Post #4,369 of 6,951
confused...
look in the menu above colour theme and you will see UI theme, its located there. I also noticed the top bar has migrated to the bottom bar pull up menu!
Sep 19, 2018 at 8:53 AM Post #4,370 of 6,951
Thanks!
Now it's clear - the OTA update actually didn't work, the version on the HiBy support page is V1.11, and the link posted above gives me the error message "Server Error"
On the HiBy webpage there is not even a version information...
https://www.hiby.com/znnr/list_47.aspx
Looks more like a "mom & pop" style company than a serious player in consumer electronics...
Sep 19, 2018 at 9:39 AM Post #4,371 of 6,951
OTA got stuck for me and the speed was abysmal. I guess a lot of people must be trying to access at the same time. Downloaded it from link above and it updated successfully.
Thanks @XVortex
Sep 19, 2018 at 10:04 AM Post #4,372 of 6,951
Thanks @XVortex
Yes it is slow normally just BW limiting.
I found that cutting off and restarting did help if it stalls.
Looks like the LDAC and APTX issues I had have been resolved.
I did have a crash and had to reboot twice.
Error -13. Anyone else have that ?
No ABC quick scroll in files/folder list though
Volume image has changed.
New theme is nice.
going back to tracks origin after reboot still goes into main file list? not sure why they did not sort that out?
Sep 19, 2018 at 10:06 AM Post #4,373 of 6,951
New theme is nice.
And dont forget the new battery indicator. :)
Sep 19, 2018 at 12:08 PM Post #4,380 of 6,951
Just received the brown R3 case and Moon Audio Bronze Dragon balanced cable for iSine to complete my current portable setup :-)
