The HIBY R3 I- Removed info on Earlier R3 Versions - Added R3 II Specifications
Sep 14, 2018 at 3:18 PM Post #4,351 of 6,951
I'm a bit late for party, but anyway, here is my review of R3
Thank you, great review. I am new here, but have actually watched many of your online reviews over the past few years!
As you say, this is a fantastic looking & compact DAP with a superb form factor.
My criticism of the R3 from a design point of view is the physical buttons.
I wish they had kept to the same button style as on the R6 (individual circular buttons). The smaller the device, the easier it gets to use spaced out round buttons (as per 2nd gen Shanling DAPS).
And even then, it is a shame that HiBy changed these buttons from the original kickstarter design. Originally the reverse-skip / play / forward skip buttons were 3 separate buttons - compared to the final retail production that merged the 2 reverse-skip/play buttons into a (cheaper) rocker button.
Also, all the buttons are way too shallow. From a tactile experience, with its rounded corners and recessed button profile, it makes the R3 too sleek that it easily slips out of the hand. I find it it easier to grip and gently hold onto when its in the plastic case ..... which unfortunately makes the depressing of the buttons even more difficult to identify and use.
It may sound harsh, but the overall design and size is so good - its the only thing [software issues aside] that stops it getting a perfect '10'
Sep 15, 2018 at 1:55 AM Post #4,352 of 6,951
Another design flaw i have noticed, the power button, and volume up/down button placed same place on both side. When you hold the R3 and want to press the volume up/down button the power button may press if you are not careful. I agree with you, rounded buttons are good when the device is small. In that case Hidizs Ap80 designed perfectly.
Sep 17, 2018 at 10:15 AM Post #4,354 of 6,951
My R3 won't let me connect to 3.5mm jack anymore. It's stuck on "BAL" and will only play either on bluetooth or balanced out and the "Output Selection" on play settings is greyed out. I've already tried restoring to factory settings, downgrading the firmware, but nothing works. Anyone else having this problem or has solution on how to fix it?
Sep 17, 2018 at 11:03 AM Post #4,355 of 6,951
no but seriously - I've had some strange behavior (like not being able to connect to wifi or bluetooth, or despite refreshing the music db, not having all my files or having the metadata screwed up etc). And the only thing that fixed it in some cases was to do a full factory reset and basically start from scratch.
Sep 17, 2018 at 11:37 AM Post #4,356 of 6,951
Check there is no fluff down the socket.
Dont push anything in like a stick as you could damage the connector.
Try blowing into the hole without spitt :)
Sep 17, 2018 at 2:43 PM Post #4,357 of 6,951
Hi all.
Just received my R3! Also been using a Tarkan mod iPod 7G and Fostex Hpp1 for 7yrs!! Lol
What do I do?! I need Hiby music and Tidal but am a complete Android noob!
Cheers
Nick
Sep 17, 2018 at 3:09 PM Post #4,358 of 6,951
Hi all.
Cheers
Nick
AFAIK, the R3, unlike the R6, does not run on Android. Instead, it runs on Hiby’s own HibyOS, which i believe is linux based.
As for Tidal, functionality is currently broken. Hiby claims to be working on a fix, but for now you are out of luck - like me :(
Sep 18, 2018 at 3:54 PM Post #4,361 of 6,951
V tempted to buy the R3 especially now it’s been released in red on their web and not just on Taobao for China.
Anyone felt that the output was a tad low at 56mW?
Im using the DX120 & Opus 1S as comparison. Thanks all!
Sep 19, 2018 at 4:07 AM Post #4,363 of 6,951
Firmware 1.14 for R3 is out.
Message get from HiBy Facebook page :
Firmware 1.14 on R3:
1. Added theme style in system setting: NIGHT theme.
2. Fixed the problem that playback does not pause when unplugging the headphone after enabling the option "Crossfade".
3. Fixed the problem of sound delay when Bluetooth output.
4. Fixed accidental disconnect failure when Bluetooth input to the mobile phone.
The OTA update available right now
Sep 19, 2018 at 5:06 AM Post #4,364 of 6,951
I like the new theme, glad to see even marginal improvements.
The big feature missing, for me, is the possibility to cue a bunch of songs to be played one after the other. The feature is present in the full android Hiby app. I just don't understand if it is impossible to implement it on the R3 because of hardware or software limitations or it is in development. About Tidal, the bugs are still there, some songs will never play for whatever reason but I understand this might be harder to solve because it involves a third party service.
I'd like to hear from Hiby but do they even have someone reading this thread? Their web presence is rather disappointing. I see they are advertising a lot their products on the social media but they don't seem to care a lot for customers who backed their products since the beginning.
Sep 19, 2018 at 5:07 AM Post #4,365 of 6,951
Anyone have a direct link to the current firmware? OTA has never worked for me. thanks!
