The HIBY R3 I- Removed info on Earlier R3 Versions - Added R3 II Specifications
Sep 6, 2018 at 4:39 AM Post #4,276 of 6,951
Hi guys, i am thinking to get this to replace my ****ty onkyo dp-s1.
wondering changing to this DAP, consider an upgrade or a downgrade? or they are just two different category?
i am so frustrated with my onkyo dp-s1 touch screen problem.
Going from a DP-S1 to a R3 would be more of a sidegrade or even a downgrade in SQ (DP-S1 is a dual DAC/dual amp setup, whereas R3 is a single DAC), the UI is probably a wash where some bits are better and other bits are worse.
Sep 6, 2018 at 4:52 AM Post #4,277 of 6,951
if i would like to replace this DAP, do u have any suggestion? i like the sounds of this DAP but just the touch screen issue, i very hard to live with it :cold_sweat::cold_sweat:
Sep 6, 2018 at 5:59 AM Post #4,278 of 6,951
If you like the sound of the Onkyo and would like to stick to that signature then perhaps go up to the bigger brother the DP-X1A, the trade off is that it's a much bigger device, but you also get a much better screen and a more flexible interface/feature set due to its full Android nature.
If you want to stick with a palm size small device that is roughly the size of the DP-S1/R3 without hair-pullingly poor UI, the choices are much more limited. Maybe see if you can score an AK70MkII for cheap now that the SR15 is out on the market which should mean the AK70MkII should be discounted now or very soon.
Sep 6, 2018 at 6:01 AM Post #4,279 of 6,951
thanks for the suggestion :D
Sep 10, 2018 at 1:48 PM Post #4,282 of 6,951
Just bought one of these today. Got a cheap open box deal from advanced MP3 UK. I would like to use this as a transport for a chord mojo. Anybody able to send me a link for a decent cable?
Sep 10, 2018 at 7:12 PM Post #4,283 of 6,951
Google shanling type c cable. Multiple links from retailers will appear. Choose the one most convenient for you
Sep 11, 2018 at 12:59 AM Post #4,285 of 6,951
Maybe I will find help here,
I am searching for a case that holds my Hiby R3 and my CIEMs.
Did anyone find a good solution for that?
Or, even Better, did anyone play with a 3D Printer to get sth like this done?
I really would love to give it a go but my 3D CAD experience is extremely low so that wont work out for me ;(
Maybe smeone already solved this "issue" ?
Sep 11, 2018 at 1:42 AM Post #4,286 of 6,951
https://m.aliexpress.com/item/32834...ZVf&aff_short_key=UneMJZVf&aff_platform=msite
Sep 11, 2018 at 2:57 AM Post #4,288 of 6,951
Sep 11, 2018 at 3:14 AM Post #4,289 of 6,951
Sep 11, 2018 at 3:17 AM Post #4,290 of 6,951
He, thats a good solution and exaclty the solution I have and use currently :), but this wont work for me for long, as I need a hardcase, because my CIEMs are quite fragile and I take it everywhere, even in rough conditions :)
Aha, best I can think of then is a sunglasses case that's thick enough? Have to do some searching.
I have that case and unfortunately, it's just a tad too small for the R3.
EDIT: https://www.aliexpress.com/item/Rec...5ca1-427c-824c-a1aa3207df8a&priceBeautifyAB=0
Maybe this can fit the r3?
  • Kae0
