seanwee
- Jun 9, 2015
Using the HD600 as the baseline, here's what I thought of the other two. I am using my Opus 1 metal which is a bit warm.
Vs LCD2-C
Lows : There is quite a bit more sub-bass.
Mids : Very slightly recessed compared to the HD600.
Highs : Slightly darker and not as airy
Sound is more articulate. Soundstage better defined and deeper with a more 3d effect instead of just being wide. Layering and separation is better because of this. Detail level is slightly higher.
Vs Sundara
Tonality
Lows : Still more sub-bass than the HD600 but not as much as the LCD2-C and its more controlled.
Mids : Sounds similar to the HD600
Highs : The airiest of the 3, it feels more open
Compared to the other 2, the Sundara sounds noticeably more transparent. Where the other 2 have a slightly softer attack, this has a sharper and thinner attack. Soundstage wise this has an open feeling (probably due to the airyness). It's as detailed as the the LCD2-C but details are a little more noticeable especially in the treble.
The HD600 is the most comfortable, the Sundara is a bit bulkier and the LCD2-C is the heaviest and most uncomfortable. It's clamping force is a bit too much.
The LCD2-C is a little easier to drive compared to the HD600. The Sundara is a little bit more power hungry than the HD600.
Vs LCD2-C
Vs Sundara
Tonality
