rr12267
Hey Majo, glad to hear that you are really liking the R6 Pro!
I wonder if there is much difference between the £500 R6 and the £800 R6 Pro? I reckon that the DAP makers are getting a bit too greedy with their prices!
I have started to use bluetooth a lot, so how does your R6 Pro sound?
Hey Jerick, how is your N6ii sounding over bluetooth as I remember when you first got it, you said that you heard some electrical noise?
From what I’ve read the pro has a redesigned amp section. I believe the output impedance on R6 is 10 ohm while the pro is 0.5. Also R6 I believe uses 2.5 mm balanced and pro 4.4 mm. There could be more but I believe those are the major changes. Oh, I believe R6 is android 6 while pro is android 8.
