The Audio Lounge
Aug 17, 2017 at 5:40 PM Post #1,576 of 36,163
For those who are interested, should be getting a prototype of the IMR-R1 tomorrow from Bob for a week's loan to do some impressions/comparisons with other gear I have at the moment (including the Hunter) - he's said it is the final tuning, but a few bits and pieces (cable and filters) look a little different on the production models.
Won't post anything up straight away (presuming Royal Mail deliver it to my office tomorrow, which is always debatable), but should be able to spend some time with them this weekend and get something posted early next week.
Aug 17, 2017 at 6:08 PM Post #1,577 of 36,163
This actually brings up a topic that I wanted to broach with this thread. Sorry about the length, but this is a discussion thread. Let's discuss...
DAPs and their functionalities & sound vs DAP with an additional AMP.
Setting the stage:
Since I got my first set of good headphones from my wife for an anniversary gift (AKG-702), I have had a portable amplifier.
I started out with an iPod touch > Headstage Arrow 2.2g amp. This had 3-6-9 dB of gain to choose. And I could use it with the AKG or my Ultimate Ears Triple-fi. This also had a bass boost, and 2 headphone outputs. Great for sharing a tablet on a plane.
I was also told (and experienced) that the power output of the iPod wasn't as good as an external amplifier. So I had ABSOLUTELY NO PROBLEMS running a stack. I would use the line out of the ipod to bypass the inner amp circuitry and input to my amp. I was perfectly happy.
(It just so happens that I also am a devoted user of MP3Gain. That makes all of my tracks the same level (approx 90dB) so that when I'm listening to shuffled songs, they all sound about the same and I don't have to adjust the volume. But the downside to that is that the signal level is significantly reduced on the iPod. So amplifiers work wonders with that as well.)
As I got more and more equipment and headphones, I also started re-ripping my collection of MP3 320 to FLAC Level 5. (Still working on that.)
Initially I downloaded a FLAC player for the ipod touch. But that was just not gonna cut it. Too difficult to use, not enough memory. Not an Apple product on an apple device. All those reasons.
So I bought an iBasso DX50. My first (non ipod) DAP. Worked well. sounded good. Decent price. Then i continued to read about all the new DAPs coming out. But I didn't find anything in price to features that would make me jump. (Until this month. more later.)
Amps:
In the meantime, I was also collecting amps. My target amp was the Ray Samuels Audio Intruder. I selected this amp because I heard an RSA SR-71 at a meet. I also heard one of the Meir Audio Corda amps and liked it just as much. But it didn't have a re-chargable battery. Just replaceable 9V. I wanted something I could charge.
And, the Intruder was not cheap. So I picked up a Niko Soundlabs V2. It was cheap. (Good amp from England. But Line-in, not digital.) Then I bought the RSA Intruder. Then I found a desktop receiver that I only use for headphones. The Peachtree Audio Decco 65. And I bought a Unison Research SH tube amp (desktop). And I bought a smaller RSA Predator.
Question:
So here is my question to the group.
Has anyone considered finding an amp, or a DAC/Amp that you really like, and then finding the DAP that will best match with that amp?
I started this journey as being 100% portable (or transportable). I never sit in front of a computer to play music.
Supporting Data and opinion:
My assumption is that people want the best sound (to you). To get the best sound, I want to get the best files that I can hear a difference. For me, that is CD Ripped FLAC for my DAPs, and MP3-320 for my iPods. I have a few High res files, but I'm still determining if I can hear a difference. After the file, wouldn't you want the most direct route to be to your decoder, amp, and then headphones? Some people like amps that color the sound. Tube amps, for example. Some want no color at all and want the amp to be a direct cable that only amplifies signal.
So my thinking would be get the player that will give you the file resolution playback you want. Then pick the DAC/AMP that fits you. Then connect them.
Suggested DAP/DAC/Amp combos:
An example of this would be the Cayin N3 or the Shanling M1 or M2S to a Chord Mojo.
These DAPs are 150 to 200 dollars and you can connect digital out to the Chord Mojo. (more expensive, but supposedly worth it.)
The Daps will play the resolution you want, and the Mojo will decode it and amplify it. (I've not heard the Mojo, but I have heard many good things about it, and it is on my target list to try.)
The solution I have right now is the N3 > digital out > RSA Intruder. I'm still using my old tried and true setup, but now instead of line-in, I'm using the DAC input. So the N3 is only acting as file transport.
The main difference in my setup and the mojo setup is the resolution of my DAC. The Intruder will only decode 16/44. So that is fine and dandy for me.
Other options I've see are the ifi. Some speak very highly of the ifi micro black label DAC/amp.
I'm sure there are as many options out there.
I fell like if you find an amp you really, really like. You can tailor your transport to the needs of your Dac/amp, and the sounds you like and are looking for.
Answer to Bob's question:
@JustBobski . I would suggest you look at the N3 and Shanling M2S. Both have been proven to do digital output to the Mojo.
Mojo can decode just about anything that is thrown at it.
Both have Hiby link that can use bluetooth transmit from your phone to the DAP. (But it is low rez bluetooth. They will not receive ABX blootooth, but will transmit it. So you can use tidal from your phone to the Mojo. (Mojo also has the Poly option, but the Hiby link is cheaper than Poly.)
And, of course, you can listen directly out of the headphone jack. I would not suggest N3 if you need to do LINE OUT.
If you don't listen to high resolution files, I really like the Intruder. But why limit yourself.
JaeYoon
@JaeYoon . I was also thinking about you and your magic flower pot when I came up with this quesion. With the Aune A3, and the Opus 1 through 20 you are buying, plus the We Kann do it... I'm suggesting you look at a cheap transport that does everything you want and supports your files with usb digital out, or coax out. Then find a DAC and amp that suits your sound with all your 5 or 6 CA iems. (ha ha)
Downside:
The biggest downside that I've seen is that people don't want to carry around a Brick, or a stack, or a stack of bricks. That is valid. I have a 49 dollar Fiio M3. It plays flacs. I use it when I cut the grass. But if I want to actually listen to quality music, I pull out the N3>Intruder>Hunter. Awesome sound. For portable, I still have a stack. I use my ipod nano > permanantly mounted to my RSA Predator > Trinity Delta VII. It fits in a small camera case and in the pocket of my cargo shorts.
Thoughts?
Flame me. Agree with me? Don't care? Tell me what you guys think.
No worries! Im good actually with Metal Opus 1. Majo and miko and me got one.
It works well with just about any iem.
Aug 17, 2017 at 7:26 PM Post #1,578 of 36,163
One definite thing I'd like you to speak for me on when testing it out and double-checking some of the details: are they TRULY standard 2-pin sockets? If I pull the cable from my JH16 or buy a 0.78mm 2-pin cable from ANYONE, will it fit in the socket? The description of the Hunter socket was absolutely not the full truth; it's 0.78mm 2-pin, but only fits a cable you'd buy from Trinity where you specified that connector because of the stupid notch in the socket. I'm holding off on the pre-order until sometime next week, hopefully you could give some short impression by then. I know you've been a busy guy with your reviews :wink:
Aug 17, 2017 at 7:32 PM Post #1,579 of 36,163
They supply USB otg type c cable so there is a possibility it has been implemented and there are small form factor flash drives available.
https://www.oempcworld.com/mm5/merc...Vld497oY8gON40mYafA5w0B0xOFUnWRRoCvOsQAvD_BwE
It seems like USB otg works on ap200 as per a comment on Kickstarter.
Aug 17, 2017 at 8:13 PM Post #1,582 of 36,163
The AP200 really does look good, wish it came out abit earlier before I bought my M1s, would've went for that instead. Oh wells! Looking forward to hearing impressions on the R1. Could be a future purchase!
Aug 17, 2017 at 8:24 PM Post #1,583 of 36,163
@Jackpot77 saw your initial impressions on the Athena, how would you compare them to some of Campfire Audio's offerings? (Vega & Andromeda)
Aug 18, 2017 at 12:05 AM Post #1,584 of 36,163
Pics or didn't happen :wink:
Aug 18, 2017 at 1:34 AM Post #1,585 of 36,163
Did you get your 8-braid cable for the Hunter yet? They don't have the odd notch in the side of the connector, and they fit perfectly well in the 2-pin socket. Wonder if it was made a tiny fraction wider than a normal 2-pin socket? Will definitely let you know, though.
Will be doing some full comparisons between the Athena and Zeus-XR and the Andro and Vega over the next few weeks when I get through the reviews, but quite quickly, the Athena does share some similarities with the Andromeda. Both are nicely detailed, musical sounding monitors without any major bias in one particular frequency range. Athena are probably a little more mid forward, and the Andro are airier in the treble than the Athena. I certainly think they are both on a par in terms of overall SQ and just general quality. I'm surprised the Athena doesn't get more positive press on here, considering how much everyone loves the Andromeda (and rightly so, it is a great piece of kit).
I'll try and get some more concrete A/B comparisons done this weekend if I can.
** Edit: horrendous autocorrect errors removed - check the quote below to see my first attempt! Blasted smartphones :wink: **
Aug 18, 2017 at 1:54 AM Post #1,586 of 36,163
Did you get your 8-braid cable for the Hunter yet? They don't have the odd notch in the side of the connector, and they fit perfectly well in the 2-pin socket. Wonder if it was made a tiny fraction wider than a normal 2-pin? Will definitely let you know, though.
Will be doing some full comparisons between the Athena and Zeus-XR and the Andro and Vega over the next few weeks when I get through the reviews, but quite quickly, the Athena does share some similarities with the Andromeda. Both are night detailed, musical skidding monitors without and make bid in one particular frequency range. Athena are ourfinally a little more mid forward, and the Andro at airier in the treble than the Athena. I certainly thin they are both on a list in the of overall SQ and just general quality. I'm surprised the Athena doesn't get more positive press on here, considering how much everyone loves the Andromeda (and rightly so, it is a great piece of kit).
Moedawg also cheering me on in PM to get Athena customs. because of cool designs.
I talked to Jack, he's urging me on saying I can select universal size, and make my own custom Athena with their cool designs. Just note in Universal size instructions.
At same time, Campfire Email says Andromeda I won't regret.
AHHHH Athena customs are so expensive but looks so good can't decide!
Or I could just buy stock and not wait 4 weeks lol
Aug 18, 2017 at 2:03 AM Post #1,587 of 36,163
Too much gear to purchase, too little cash. Life of Head-fiers...
Aug 18, 2017 at 2:14 AM Post #1,589 of 36,163
Right, I want to pick both, but I can't. OMG
:c I gotta only pick one. But even then it's so expensive lol
not only that, emailing both companies. Jack is awesome, and Ken ball too.
They are both great people. arghhhhhh
The best solution is to buy from a different company all together. Haha.
