analogsurviver
- Jul 2, 2012
Yes, F=ma as mentioned in the document. Written differently: a=F/m. With more mass you just need more force to reach a certain acceleration. If you increase the mass, and you increase the force (by increasing the current, by increasing the voltage) with the same ratio and everything stays the same (all other things being equal). Only efficiency is lower.
(By increasing or decreasing the volume, all acceleration of the driver's moving parts is increased or decreased by the same factor, the resulting wave shape is identical except for the amplitude, simply giving lower or higher volume. The same should hold for adding mass to the driver: simply gives a lower volume. Again, all other things being equal.)
[Edit3: Actually the force has to move more than only the mass of the moving parts of the driver, but also the mass of the displaced air, plus mechanical resistance of the suspension. So things are a bit more complicated. But that doesn't mean that increased mass can not be compensated for with increased force.]
In the "all other things being equal" there may (or may not) be complications, but Newton's 2nd Law of Physics doesn't cause any problems for the above!
[Edit: By the way, related to this: The reason why multi-way loudspeakers use different sized drivers for different frequency bands is not that larger and hence heavier drivers would not be able per se to reproduce the higher frequencies, but because the dispersion pattern depends on the ratio between wavelength and driver size. Large drivers will beam the higher frequencies more than low frequencies.]
[Edit2: Electrostatic loudspeakers have the reputation to be "fast and precise" supposedly because they have a very light membrame. However others claim that in reality because of the narrower dispersion pattern of the large driver surface there are less reflections and reverberations, and that can be perceived as increased "precision".]
Correct - as long you CAN increase the force. This ends with low SPLs, where you can not increase the force - because for certain SPL it is given and adding any more force woul increase SPL required - which is forbidden if the accuracy is to be maintained.
Regarding ESL vs dynamic drivers. Correct - to a point. Please go trough the paper of Peter Walker from Quad - where he describes the design of push pull electrostatic design , which is now almost universally adopted by the vast majority of manufacturers.
Save one - for which said late Peter Walker is quoted as saying which loudspeaker not developed by him he would have liked to be his brainchild.
The main difference between a dynamic and an electrostatic driver is in the fact that ESL diaphragm is - across most of its range, if designed correctly - damped by AIR - therefore not requiring the Aichille's heel of any dynamic driver, which is the inevitable departures from the perfect piston motion in most dynamic drivers. Even if we limit the dynamic drivers to the free open air performance of dipoles ( ribbons, planars, etc ), without having to deal with the more common issues of enclosure problems, there usually is still the problem of dynamic driver having larger mass and therefore worse performance.
Only recently there have been breaktroughs in this regard - dynamic drivers capable of better transient response than ESLs. ESLs are notoriously hard to drive in electrical sense in the treble ( requiring drive that is, in EU at least, forbidden to be sold to the general public due to safety ) and the fact that stator electrodes in ESLs are extremely hard to make to be both acoustically as transparent as possible while having low mechanical resonance - the two being mutually exclusive and always the hardest compromise any manufacturer of ESLs is faced with.
Although most ESLs are quite>very>extremely directional ( to the point I would definitely prefer headphones over "head-in-a-vice-loudspeakers-or-extremely-poor-sound" , there ARE ways around it. At least two - mentioned above, albeit not explicitely. One behaves like a dipole, another as a full height line source. Both still offer better /less exitation of room modes and reflections than a common dynamic speaker in a box - not to mention inherently better transient response and far lower THD.
Currently, the fastest transducers available are both EARSPEAKERS - MySphere 3.2 ( a very advanced dynamic full range driver ) and RAAL Requisite SR1a ( world's first full range ribbon ).
Similar level of performance in loudspeakers is available in Alsyvox range of planar/ribbon from Spain. I do NOT want to go and audition them, despite one of my acquaintances owning a pair in less than 10 km range.
Entry model starts at 60+kEur ...
