jcx
- Jul 24, 2002
monitoring the V going to the headphone seems like the most practical method - with a Y connector and a a high R ( 10 kOhm is enough to avoid extra loading with dynamic headphones) V divider you could use a soundcard line input
the soundcard line in may be as bad as a few % absolute accuracy, channel matching but the repeatability/resolution should be better than 0.01%
if trying to check headphone cable properties you may want to probe the V at the headphone driver terminals inside the cups - less easy
the subjective comparision is always difficult with taking the headphone off, replacing it on your head, the physical placement, sealing (got hair?) giving changes in frequency response that should be ABX audible
