I should point out that, like many things, nobody has performed any tests of the audibility of jitter in modern DACs.
(There are one or two very old tests, performed on very different equipment, which suggest that it is largely mostly inaudible.)
I should also note that the popular "J-test" used by many magazines does NOT in fact measure jitter.
It actually applies a "stress test signal", then measures the output noise spectra.
This fails to differentiate between jitter from the source, jitter generated internally, jitter caused by the input circuitry, and jitter removed by any processing.
(It's the equivalent of "shaking the box and listening for noises caused by stuff rattling around".)
Since you asked, while our output spectra tests show the results of any jitter which might be present, and so would alert us to any "jitter problems", we do not measure jitter directly.
(Measuring jitter directly is very difficult, and requires an expensive, and extremely specialized, extra module for the AP.)
The product page for the DC-1 is no longer online - because it is discontinued.
However, at least for now, you can download a copy of the AP test report for it here:
https://emotiva.com.ua/pdf/dc-1/DC1_AP_Report.pdf
I haven't seen one for the Wyred4Sound (and we didn;t run or save one).
