gregorio
- Feb 14, 2008
[1] I am a proponent of how our perceptions are always changing and can effect how we can "hear" something from day to day.
[2] The main "controlled" anecdote I have is the computer vs iPhone source through my Benchmark.
[3] My bias was that they'd sound the same: so I was taken aback that they sounded different.
1. I'm a proponent of our perceptions do change, subtly over time and sometimes quickly and quite dramatically but regardless, our perception constantly affects how/what we "hear". Just the fact that you listen to "music" and can differentiate music from semi-random sound/noise demonstrates that fact.
2. I'm not sure how "controlled" your test was, or even if you were testing what you thought you were testing. For example, you might have just been testing an impedance difference in the supplied signal, noise/interference from the computer's USB output the DAC was not expecting/designed to cope with on it's coax input or various other possibilities.
3. A lot of audiophiles fall into the trap of thinking that "bias" is that thing which they consciously expect. This is an erroneous belief! We all have numerous biases, some/many of which are sub-conscious and can take precedence over conscious biases. Furthermore, expectation bias itself isn't just one thing, our "expectation" is usually a judgement comprised of various different expectations and again, some of our expectations are sub-conscious and therefore not taken into account. An example of this is the Mcgurk Effect, watch this 3 min video. but first I'll tell you (even though it states it in the video) there is no "faa", you only ever hear "baa", there's no difference. You should now have the conscious expectation of there being no difference and you shouldn't hear "faa".
- Blind listening comparisons with matching of volumes and music segments, and ability to switch rapidly: should be better than casual sighted listening comparisons, but could still be unreliable, especially for detection of small objective differences in the physical sound
Sure but why doesn't your summary include the other obvious missing points? Shouldn't your summary effectively be:
1. Casual sighted tests can be (typically are) unreliable.
2. Blind testing has it faults but is typically more reliable.
3. Double blind tests are typically more reliable still.
4. DBX test are typically the most reliable.
No test is absolutely reliable although with a sufficient sample size we can get close. The gap between the first point and the second is typically larger than between the second point and the rest because a casual sighted test is by definition "casual", while the other testing methods are usually less so. For example, as you mention, blind testing usually includes matching volumes and material, thereby eliminating potentially serious testing flaws. And, ABX testing typically allows instant switching and the comparison of extremely short extracts, thereby eliminating the limits of echoic memory which can affect the other testing methods.
G
