bigshot
I have Christmas lights strung above my stereo system. It gives me the "warm glow" of tubes with solid state fidelity.
Wow! There's a whole magazine for amateurs!
Just to be transparent ...i have owned(and loved) some truly beastly tube amps(sonic frontiers power2 to name 1)they would drive antthing.....but i don't believe for a second that they couldn't be equaled in ability to drive speakers or headphones by solid state devices(sonics might be debatable...maybe)We are talking about volts/ohms/amperage here ....solid state is king here my friend.Unless of course you are fllying an older MIG fighter jet where tubes where used for there immunity to EMP.
Now you're trying to say that designing an amp that is flat is harder to do than one with rolled-off high end??? Nonsense! And then you say headphones exceed the requriemenst of speakers for drive in the HF range? Again, nonsense. Electrically, that cannot be. The impedance of an electrostatic speaker drops to below 2 ohms at high frequencies. The impedance of electrostatic headphones is nowhere near 2 ohms....it's more like 20K or higher! With a tiny capacitive reactance or 150pf? Why, on earth, is that hard to drive? You're theories defy physics.
You should re-read the above. You just said the electrostatic headphone amp needs to be the size of the Sanders amp, but only not the size of the Sanders amp. You're counteracting yourself. Which is it? I can't be both. And again, where's all that power going????
Hogwash. I have the right probes in my junk box. Several copies.
Please state the model number. Standard Tek 10X probes would be just fine.
Sorry, this is also nonsense. You should work with RF for a while, and get used to working around 100mHz or so...then get real. It's all measurable.
Why do you think a capacitor doesn't dissipate heat? Unused power is converted to heat. Always. Make the load capacitive and it changes how you calculate it, but it doesn't get converted to acoustic energy, and it doesn't just vanish. Remember, conservation of energy? It all can be accounted for. It has to be. Sorry, that's physics.
However, the reality is, you're not dumping 70W or so into the drivers, they are far too high impedance for that. They're handling likely about 2W, possible 5W tops. Look at the impedance of the drivers your working with. And most of that power is lost to heat because you're not shoving 5W at your ears at close range without permanent damage.
I might suggest you do the same. Please note the power consumption of the above device then come back and tell me how it delivers 70W to the headphones. And why you'd want to in the first place.Just in case you plan to continue with this lunacy, please DO check https://ifi-audio.com/portfolio-view/pro-iesl/
Ever heard of resistors? They're great for getting voltages down.Just how do you expect normal 10x probes rated at 400 V to survive 640 VRMS ( it CAN exceed this value, it is only spec'd at it ... ) ?
Knock it off.You do know what VRMS means ?
Did you check the pricing? The P5122, which would be just fine in this application, is completely affordable. But also, unnecessary. I own two HV probes, 15KV, 100mHz, and I think I got them used for $20.Only 1:100 probes are really suitable in the case of electrostatic amps ( the BIG one produces over 10 kVpp output ... ) - and here they are : https://www.tek.com/high-voltage-probe-single-ended
Knock it off.
Now look. I've raised numerous objections to your nonsense. You chosen to ignore the key ones and focus on what? A high voltage probe? And somehow are trying to use that argument as some sort of excuse for what? Why some amps aren't tested? OR we can't build an adequate ABX switcher?
Well, let me remind you. You claimed that an ABX switcher that added to the already tiny capacitance of the system would be inadequate for the job and could not be built. I countered that, both with that it could easily be built and questioned that adding a bit more C would even cause an issue. You responded with, "The only thing you are probably correct in this post is tha ABX switching device could be conceived without too adverse effects."
So, we're done. We agree about the core issue. All the rest of this is more nonsense that clouds the core issue. So if you have any other pertinent points to make, other than insulting me, then make them. Or move on.
Yes, ABX/DBT in the case of comparing electrostatic headphone amps/energizers must be done with the same pair of headphones. 5 second switching time is unacceptable. However, anyone who can design such a high voltage amplifier can easily conceive of the correct design for a switching device, and capacitance should not be a problem.
Are you seriously trying to say that the amp, normally driving about a 22K load, can't deal with an additional C of up to 50pf without changing response? Seriously? The capacitive reactance of your 145pf headphones and cable is about 33K at 30kHz! No amp designer worth his salt would attempt to drive that with a matched source Z in the first place, so the 10:1 rule would still apply.
The additional possible C of any switching system would absolutely NOT be a problem. At least on Planet Earth where the laws of physics still apply.
Oh, really? So where's that power going??? If it's not going into acoustic energy (which is absolutely is not), then it's going up in heat...in the drivers....on your head? So, you want a pair of 70W light bulbs strapped to your skull? You plan 2 minute listening sessions with 6 weeks of healing?
The resources you should seriously attempt to acquire is technical knowlege and understanding of electronics and physics.
How is the above to be read without insult?Now, this is NOT meant to insult.
You have failed - miserably so - at understanding the CORE problem of DRIVING the electrostatic transducer.
I just re-read Walker's equation. You know, the one that states that if an ESL is driven with constant current the response is flat, but because it's capacitive, it has a 6dB/octave rising response with constant voltage. The conversion of electrical energy to acoustic energy therefore occurs also on that 6dB/octave slope. And therefore, the ESL cannot be 100% efficient at any frequency. In addition, because of the diaphragm being a dipole, half the acoustic power is emitted from the back, so the forward efficiency must be -6dB below the total. And all of that is without considering the actual efficiency of conversion from electrical energy to acoustic.Electrostatic transducer is 100% efficient over most of its operating range, but most notably the midrange - EVERYTHING gets converted into sound, that's why they are considered the best , particularly for midrange.
But, it's a capacitor, so it has changing impedance with frequency. When you look at the spectral energy distribution of music, it's about 20dB lower at 20kHz than it is below 1kHz. The amp needs to tolerate a low, capacitive, impedance. That's it.Above was for ACOUSTIC efficiency of transduction. Electrical efficiency is an entirely different matter - as driving the electrostatic driver does not only mean swinging the volts required, but it requires CHARGING that capacitance first in order to be able to swing that voltage... Yes, you need ever higher output/current capability of the amp with ever increasing frequency - and HERE lies the core problem. Before you know it, Volts multiplied by miliAmperes required mean - BIG amplifier.
This is the kind of statement you make that I have the most trouble with. A capacitor, ANY capacitor, is not a dead short, ever. Capacitive reactance means its impedance drops with rising frequency. It some frequency the impedance becomes very, very low, but it's still capacitive reactance. Depending on the capacitance, the actual load presented to an amplifier can be anything, and for an ESL will drop quite low at high frequencies, but there's very little energy up there, and with rising efficiency of an ELS, less power...much less power...is required to drive that very low Z load. A capacitor is not a dead short, and does not require infinite power to drive when you consider a meaningful value for an audio device. A dead short has an impedance of zero ohms at all frequencies.Basically, NEVER enough power - as capacitor is ultimately dead short, requiring infinite power to drive.
Got an actual reference for all of that?The funny aspect of this is the fact that some of the world's best subwoofers are - electrostatic ! They can be made to operate at near 100 % efficiency ( normal dynamic driver loudspeaker howers around 1% efficiency - 100 W electrical input produces 1 W acoustic power output ) - and imagine WHAT can be achieved with two 10 W ( more appropriately : 10 VA ) ES amps driving those nearly 100% efficient electrostatic subwoofers. For anything required by the subwoofer in frequency, the impedance of the driver remains so high that hardly any current is required from the amp - FYI, the acoustic power output of a symphony orchestra is "around" 5 watts IIRC ...
True, and when the frequency goes greater than the frequency resonance of the circuit (its lowest impedance point), the capacitor starts acting like an inductor, and lags the voltage.But, it's a capacitor, so it has changing impedance with frequency. A capacitor, ANY capacitor, is not a dead short, ever. Capacitive reactance means its impedance drops with rising frequency. It some frequency the impedance becomes very, very low, but it's still capacitive reactance.
Yes, true. But amps run out of power/current WAAAAY before this frequency is ever reached in practice. The result is slew rate limiting - which sounds anything but nice.
