gregorio
- Feb 14, 2008
[1] G - enough of that, please. We are both describing the same thing from different perspective - and it is getting tiring you latching to any word I do put wrong here and there.
[2] You are also - quite a bit - overconfident of what can and can not happen in real musical event
[3] I DID MANAGE TO FIND ALMOST PERFECT SQUARE WAVE ALIKE SIGNALS IN MUSIC FROM LP.
[4] those astonishingly close to square waves occur on this ORIGINAL DIRECT TO DISK recording
[5] The instrument(s) that can produce such almost square wave like signals ( of course, no such thing as PURE square wave in real music ) are usually brass (groups) - big band jazz or similar.
[6] It is amusing that the instrument that produces the purest sine wave like signal is also from the brass family - french horn ... - almost pure sine wave, with very little (if any at all ) harmonics.
[7] If an almost square wave looking signal can be recorded to an analog record in real time ( record cutter having flat response max to approx 27 kHz, depending on the cutter head model )
1. I tell you what, I'll stop refuting your nonsense if you stop posting it! And, I tell you what's really tiring, is the fact that your "wrong words" are not "here and there", they are here, there, in between here and there and almost everywhere else, which is why almost every fact/assertion you make is nonsense.
2. Evidence or it's nonsense/trolling.
3. Evidence or it's nonsense/trolling.
4. Evidence or it's nonsense/trolling.
5. Evidence or it's nonsense/trolling.
6. Evidence or it's nonsense/trolling.
7. Evidence or it's nonsense/trolling.
The rest of your post was just rambling and irrelevant. You STILL haven't bothered to learn the very basics about square waves or about digital audio, so most of the above points are irrelevant anyway. What's the rise time of a 20kHz sine wave? Are you going to assert that rise time can't be perfectly captured at CD sample rate? And, what has rise time got to do with channel sync/phase in PCM anyway?
G
