gregorio
- Feb 14, 2008
[1] Personally, I recognize the limitations of using only 2-mics. They can only pick up (attenuate) a limited range of dynamics. If we had mics as sensitive as our ears..well then binaural would be much different.
[2] What was the particular myth or claim about binaural again? Whether it was effective or commercially viable?
1. Actually, I see mic dynamic range/sensitivity as one of the least of binaural's problems. The Shostakovich 5 you linked to for example is probably an accurate capture of the sound waves (including the dynamic range): The noise of the audience is very present and relatively loud, the orchestra is rather distant, poorly defined and separated and with a rather small dynamic range. But, this is NOT a limitation/problem with mics, the mic's have done their job and captured the sound waves. The problem is with perception or rather, the lack of it! As I've stated before, although this may be an accurate representation of the sound waves, it is NOT an accurate representation of what one would likely experience, due to human perception, which binaural recording cannot represent at all. As a consequence of human perception (the brain's processing), the actual experience sitting in this same location would likely have been; much less audience noise, less room reverb, more clarity, definition and separation of the orchestra and a somewhat larger dynamic range. We can represent this experience using multi-mic recording and mixing but we can't with a binaural recording.
The other recordings display other typical binaural recording problems, due to relatively close binaural mic'ing, poor balance and also accurate but undesirable positioning (hard panning). That hard panning could of course be alleviated by moving the mics further away from the musicians but then you run into the greater distance Shostakovich recording problem again; too much noise/reverb and loss of clarity, separation, etc. This highlights the problem of any (near) single point stereo pair recording, namely, that there often is no single point which solves these problems. The only solution is typically multi-mic'ing, which allows a mixer/producer to correct for positioning, separation, clarity, balance between the instruments, dynamic range and the balance between the direct and reflected sound, to more accurately represent what we would experience, expect or desire.
2. As explained above, typically neither!
[1] Before proceedenig any further, I would first like you to listen particularly to this video highlighting the importance of placing the binaural microphone :
[2] Please review and comment the above - it may well prove to be a steep learning curve, both for yourself and all the participants in this thread regarding binaural.
1. Mic placement is always of vital importance, whatever mic'ing scheme is being employed, binaural is no different to any other mic'ing scheme/technique in this regard.
2. Hmm, are you sure the steep learning curve isn't yours? Have you really listened or are you only concentrating on certain aspects of the binaural effect? Really listening and evaluating ALL the aspects is a MUCH steeper learning curve! For example, while some of the mic positions in the piano vids are better than others, they all have their strengths AND weaknesses, can you hear them all? Even more difficult, can you identify them? Sometimes the piano is effectively a single mono sound source, sometimes it's a wide stereo sound source, sometimes we get a great deal of room noise, sometimes we get noises created by the the pianist, sometimes we get too little room reverb, sometimes a bit too much, sometimes the balance and/or clarity between the high and low end of the piano is not quite right, etc. Probably there is no single point the binaural mic could be placed which would be ideal. A professional would take advantage of the strengths of the various positions and minimise the weaknesses: So for example, a stereo pair close to or actually inside the piano would allow for excellent balance and clarity between the high and low end of the piano, as much or little stereo width as desired from the piano itself and inside the piano would reduce room and musician noise and then another stereo pair (probably an A/B pair) much further away to record the room ambience/reverb and also avoid musician noise. Then of course all these mic's would be mixed together with an appropriate balance. We would gain; lower noise, better balance and more clarity/separation and we would loose what? Some small amount of absolute spatial coherency which could only be perceivable on headphones and will only be perceived as a fatal flaw by a tiny fraction of extreme headphone users who value absolute spatial coherency above lower noise, better balance and more clarity.
Surely you've made a simple error about the "binaural" orchestral recording (Arturo Marquez), like posting a link to the wrong video? Despite there being a dummy head right next to the conductor, presumably with binaural mic's attached, the sound on the video is OBVIOUSLY not from those binaural mics, it's from a stereo mic on or connected to the camera! This is a video of an orchestra rehearsing with a dummy head, not the actual recording from that dummy head! To be honest, I'm at a loss for words, I can't even imagine how is it possible to be so sensitive to the relative minutiae of absolute spatial coherency and yet so completely insensitive to massive differences in balance, positioning and aural perspective? Please tell me you've made a mistake, otherwise your learning curve is shockingly steeper than I could even have guessed!!
G
