KeithEmo
Member of the Trade: Emotiva
- Aug 13, 2014
Since this is a popular topic.... I'll add a bit to it....
Standard cables have a few well understood electrical characteristics - resistance, inductance, and capacitance.
There are also a few more complex things:
- like how well they are shielded (which varies by frequency)
- and dielectric non-linearities (which tend to be blown way out of proportion by audiophiles as a factor - but do really exist)
- (and we won't get into the specifically odd characteristics of some "specialty cables")
However, cables are one area where the associated equipment you use is a major factor.
On thing that tends to vary considerably between cables is capacitance... some cables have much lower capacitance than others... (a 10x difference would be COMMON).
HOWEVER, in general, a typical modern solid state preamp is designed to be able to drive a relatively low impedance load.
Also, even though cables may vary considerably between wire types, all of them have "pretty low capacitance" by modern standards.
Because of that, it is unlikely that there will be an audible difference between most interconnects when tested with a modern solid state preamp.
HOWEVER, most older tube equipment, and a lot of modern tube equipment, has a rather high output impedance (it is NOT designed to drive a low impedance load).
So, if you connect various interconnects to a vintage tube preamp, there's a very good chance there will be audible - and measurable - differences.
(We're talking about a roll-off of several dB at 20 kHz with some particular combinations.... which is quite easily audible.)
This will be true of most but not all vintage tube preamps, some but not all modern tube preamps, and some very few other modern preamps (mostly passive ones).
So, in this case, we can say that "it's unlikely that there will be a significant difference with different interconnects and most modern equipment".
However, we also can't rule out the possibility that there will be a difference with certain combinations.
(And, yes, if you understand circuit design, and have the right information, you can predict which ones will and will not act in which way.)
In your first sentence you point out an issue with the discussion topics being taken to extremes, and then your last paragraph about cables seems to pull in some potentially pathological extremes to justify your position. I mean, maybe in some extreme situation would 2 cables change the sound enough to be audible while still measuring similarly.
