bigshot
Generally, I agree that blind comparative testing is valuable. But I think that such testing also has limitations in the sense of potentially not accurately revealing differences which are more subtle, may be perceived more subconsciously than consciously, and/or may have a more significant effect when listening durations are longer and more like real listening.
Measurements can definitely reveal things that are more subtle, but they can also reveal things that are totally inaudible. Unless you know where the line of threshold of perception lies, a measurement is just an abstract number with no practical context. We listen to music with our ears. It's just as important to measure our hearing as it is to measure the output of our stereo system. Ultimately, our ears are the last processing of the signal in the chain. There is no point pushing sound we can't hear through the chain. If we can't hear it, it isn't going to improve perceived sound quality. Our ears are what they are. We have to produce recorded sound to suit them.
Humans do not hear more discerningly over long periods of time. In fact, the longer you listen, the more your ears adjust to accommodate the sound. Auditory memory is notoriously short. For similar sounds, the length of time is just a couple of seconds. That's why controlled listening tests have direct A/B switching so the samples can be compared right next to each other.
We do not perceive subconsciously. Hearing is a mechanical process. You either hear something or you don't. How you *interpret* the sound might have some sort of subjective spin, but being able to hear a difference in a controlled comparison test is pretty much cut and dried. The purpose of blind testing is to remove subjective or subconscious bias. You can't apply bias if you can't tell which is which. And you can't apply bias if you can't hear it in the first place.
Subjective enjoyment of music is an intellectual process, not a mechanical one. You can enjoy very low fi recordings of great music as much as hi fi. If you want to improve your enjoyment of music subjectively, it isn't hard to do that. Create a comfortable space to use as a listening room. Read up about the musicians and history of the music you listen to. Expose yourself to a broad range of music of all styles and eras to gain a wider frame of reference. Think about what you listen to. All of these things will improve your "subconscious" perception of music more than inaudible sound.
I think the upshot is that standard measurements, combined with listening, are usually 'good enough', but those measurements can still miss things which some listeners can detect.
What things are those? The way you would prove that would be with a controlled listening test. Do you know of any controlled listening tests where people were able to hear things that couldn't be measured? Or are you just assuming that there must be something because you want to believe that?
Human perception has been studied for centuries. Sound reproduction and measurements go back over 100 years. Most of the principles we're dealing with here were totally understood by the time of Bell Labs in 1920. If there is some aspect we're missing, I'm sure scientists would love to know about it so they can study it.
Analogsurvivor:
Response error = changes in tone
Amplitude error = changes in volume
Distortion = changes in the signal
It's possible for an error in one area to affect another I suppose. But timing error is changes in the signal. In its broadest definition any deviation is distortion. There are lots of different kinds of distortion.
