StanD
- Oct 2, 2013
When was this demonstrated under controlled listening conditions?
se
Perhaps that was an anecdotal post. It happens.
se
Maybe. But ABX testing still eliminates other biases, which is why it's important. So that doesn't discount the value of DBT over sighted listening at all. Plus, you obviously wouldn't have that problem, so seems a moot point.
So why not do some testing instead of all this speculation that the ODAC will sound different from chip X or that such and such filters produce an audible response?
However, there seems to be a serious misconception about what ABX testing actually gives you in most situations. In actual point of fact, all it gives you is a result showing that a statistically significant number of people could tell Product X from Product Y, and which one they "liked better", under very specific conditions. This makes it a great way for an individual to decide what product to buy, and a great way for the marketing department to figure out how many of their potential customers can hear a difference between product X and Product Y and, if they do, which one they like better. However, as a scientific tool, it's not very useful because the information it yields is not properly controlled. (Let's say it's a good way to apply scientific principles to the study of product preferences.)
I agree entirely - that ABX testing is very effective at what it does.
I guess I'm confused.... I thought this thread was about "audiophile claims and myths" - and perhaps about discussing them. If it's really only about "publishing the results of tests" then we should all just go join the AES. . . .
It's quite simple. This is not about other people. You have repeatedly claimed that some DACs sound different from others to YOU when audio science would suggest that might be not true. For validating your OWN opinion, you could ABX test.
When someone says there is a serious misconception about ABX testing and then goes on to demonstrate that the serious misconception is their own, what more can you expect?
Too bad he doesn't spend as much time trying to actually learn something as he puts into these lengthy posts of his. But I sense that he's only here to preach and has no particular interest in learning anything.
se
If had access to an ABX comparator and the means to do an accurate volume match, I'd be testing all kinds of stuff that I have because I'd like to learn.![]()
I'm willing to hear discussions that criticize DBT when it comes to comparing things like speakers which DO sound different, because I think there is more flaw to the process than some objectivists are sometimes willing to admit. But comparing to see if something is different or not with ABX? It works.
@KeithEmo
I'm one for a good analogy but I don't think that trying to equate the validity of simple audio engineering and far out string theory is in the same ballpark. Electrical Engineering is applied/practical physics and string theory is just that, theory.
@KeithEmo I'm one for a good analogy but I don't think that trying to equate the validity of simple audio engineering and far out string theory is in the same ballpark. Electrical Engineering is applied/practical physics and string theory is just that, theory.
Methinks those strings are actually straws.![]()
se
Another (in my opinion not unlikely) possibility is that the "clear" differences you heard are mainly the result of expectation bias and simple factors by level differences.
That is why the test should ideally be performed by people who do expect to hear differences. You could try some ABX tests yourself, although I guess you most probably will not.
Actually, there is a new revision of the ODAC that no longer uses an ESS DAC.
What flaws do you mean?
But yeah, with things like loudspeakers where there's no question with regard to audible differences, ABX is pointless because ABX is all about identification. But blind testing in general still has value. Floyd Toole (now retired from Harman) for example, used blind preference testing to try and correlate preference to measured performance. Such tests needed to be blind so that preference was based on sound alone, instead of other influences like looks and price.
se
