bigshot
What about when you play music with it.
You can get one close enough for human ears by using human ears. It's like anything else in audio. You can split your fractions forever using measurements, but ultimately, all you are going to hear is what your ears hear. The other thing is that a flat response isn't flat all over the room. A measurement is from one point in the room. That is great if your room is just for one listener. But if you have multiple seating positions within the room for groups of people, or if your acoustics are slightly different when you drop a screen, or if you have issues in parts of the room that can't be dealt with through room treatment, or a bunch of other exceptions to the rule, you need to be able to compromise and develop workarounds.
A lot of people think that the sound of the room should be eliminated and cancelled out. I don't like that kind of system. I like it when the system works *with* the room to create an even, balanced sound that is natural for the sound of the room.
My sound engineer buddy who helped me with my system is really good at walking into a club, auditorium or arena and quickly figuring out speaker placement and EQ to give an overall sound to the entire audience, not just the position of his mixing board. He helped me a lot with understanding the variables that needed to be taken into a account in my particular space. Every space is different and requires different approaches. You can follow acoustic principles, but some things you just have to try and see if it works.
I'm also working within the limitations of a five band parametric equalizer. It would be great to go down and smooth out every tiny bump and dip, but I have to work with five bands to create an overall curve. If I get too focused on small details, the overall won't be covered properly.
The nice thing is that it all works and the sound in my room is great. Come by and hear it if you ever get to LA.
I assume seeing as I asked politely twice that you just refuse to answer what type of unit you use for DSP.
RXV671 is the number of it I believe.
Thanks - As I stated I am not against DSP but as far as room set-up I was goin gto suggest trying the AVR calibration vs by ear and see what you think if you had it. My old Onkyo w/ Audyssey XTdid 8 and could be expanded to 32 sample points IIRC and On my Pioneer Elite it uses Mcacc with multiple measure points and several memory presets for different tweaks or profiles if you desire. Not sure which I like better and no experience with YPAO.
Something else I read regarding Audyssey and Mcacc
Time and Frequency Correction:
- The time domain is where many of the problems are. Parametric and graphic equalizers can only correct for the frequency response and do so in a very coarse manner because they have limited resolution (bands).
- Further, whether they have fixed or adjustable bands doesn't matter because bands cause phase problems that most people hear as "ringing" or "smearing." That's why, after thirty-plus years of trying this method, most people don't like the results. And they turn it off.
That was from the Audyssey website itself but here is info that may answer your question
http://www.erzetich-audio.com/knowledgebase-05-time-vs-frequency
also Phase shift and polarity aren't things you are going to ascertain by ear.
Quote:Originally Posted by Phishin Phool That was from the Audyssey website itself but here is info that may answer your question http://www.erzetich-audio.com/knowledgebase-05-time-vs-frequency also Phase shift and polarity aren't things you are going to ascertain by ear. I know what the time domain is; it's the plot of your specific sample points. My question was, for an uncalibrated system, what are these time domain problems that need time-domain DSP algorithms to correct, and why would you worry about these fixes more than achieving a flat frequency response with frequency-domain DSP?
I don't think it's an either/or situation. Why not correct both when the tools allow for it?
Agreed that if you can only correct for one, I would target FR first.
That I do not know - just relaying some info that I came across as perhaps some users may find it pertinent. I was intriguesd by the statement that PEQ causes issues to remain which come across as ringing and smearing and adjusting just the FR isn't enough. I agree - correct both.
As I am happy with my multi point Mcacc room calibration which addresses Speaker Adjustment, Equalizer, Phase Control,Speaker Polarity Check, Standing Wave Control, Subwoofer Equalizer, Independent Dual Subwoofer Output, Full Band Phase Control. I have then checked the SPL level at various points in my room and am satisifed with both what I hear and measure. I am certain I can't achieve that by ear alone.
