"Mahler symphonies can also take advantage of this - horns in the distance can also be positioned not only "far(ther) away", but also LOWER or HIGHER while still being far away -"
Correct, who said differently BTW?
"Better audio equipment is capable of at least hinting at it"
Incorrect. Totally impossible. Entirely in your head. This is nuts. Ludicrous. Illogical. Stupid.
Would anyone state that you could hear right/left with a single mono channel and a single speaker? Of course not, that's why they invented stereo, duh.
How then can anyone be irrational enought to state that you could hear height when height was never even recorded to start with? And with 2 speakers at that?
You'd need at least 3 mikes and 3 speakers to record and reproduce height... or it's fairytales territory.
But hey, sorry to bother you with facts, you don't like to be bothered by them I guess.
As Paul says, "you can't win with these people".
In theory, you are correct. As a consequence, you would end up with 2x5.1 or 2x7.1 setup - 1 setup of speakers being maximum on the floor and another maximum to the ceiling (within possibilities of placing that is never optimal too close to the wall/ceiling/floor, most likely having to be flush mounted into the walls/floor/ceiling).
However, even a mono recording can contain height. It is sad that this art is all but lost, stereo or even surround recordings can sound far more "off" than a really good mono. It does take an unusually high level of commitment in finding the right spot for the microphone and similarly positioning the speakers within the room.
Mono on headphones just does not do it for me - it is the very last thing I would choose to listen to and will be the last ditch attempt if nothing else is available.
Height is possible to be reproduced kind of correctly using 2 channels only by the binaural technique - this IS head-fi. The results are not entirely consistent , be it regarding the microphone used, headphones used, interface headphone/listener. The best documented and most repeatable results can be achieved with what was devised in Germany and incorporated into Stax headphones and corresponding diffuse field equalizers - but it is not the only way. It is not perfect, yet it will clearly show why redbook is not nearly enough. Height is the most vague of 3D in audio, depth is much more easily perceived and too benefits greatly by greater bandwidth than allowed by redbook, width being the most easy one and does not improve significantly with higher bandwidth - if at all.
All of the above is easily audible even on good IEMs - let alone the Stax setup. Saying that redbook is enough is similar to saying propeller driven aircraft is enough -
we can wax all we might, but a propeller driven aircraft will not go faster due to the limitation that when propeller blades reach the speed of sound, they practically loose all efficiency and no amount of power can change that. So the conditions (temperature, height, etc ) of the speed record attempt for propeller driven aircraft weigh perhaps more than the aircraft itself - those few km/h or mile/h differences in single digits among various aircraft are only partly due to the aircraft itself. The only real increase in propeller driven aircraft came with counterotating turboprops ( russian TU 95, civilian version Tu-114 being even faster ) which increased the speed by roughly 100 km/h, thus making a bomber faster than the fastest propeller driven fighter ever - but that is it. Any operational jet of the first generation can do better.
I have not even read the article from TAS entirely - but do grasp what it is trying to say/proove. I agree it is (too) expensive, I agree it is hard to reproduce in one's home, etc - but binaural has next to none of these limitations. And will show that redbook is not enough.
I will end with a demo record by Sennheiser - a 7" vinyl. I own the real thing, which in ANY case sounds MUCH better played "live" than the following vid on YT - but will
improve immensely by a cartridge with MUCH better bandwidth than redbook is capable of. The effect gets MUCH diminished on a cartridge that covers response only to just above 20 kHz ( vast majority of moving magnet cartridges - but there ARE exceptions ) - answering the question why moving cartridges have been soooo successful in the last 30 or so years. I only wish this could pass trough the ....khm..omputors... ( and bandwidth limitations ) - better :
Here is the other side of this record in German :
