Tempotec V3 DAP - small, powerful, functional with Hiby OS
Jan 25, 2024 at 3:04 AM Post #421 of 829
the firmware will be released within half a month - Tempotec Support.
I hurried them on, told them that we were already tired of waiting. They will also have to review all the problem sites.
Jan 25, 2024 at 10:50 PM Post #425 of 829
It was clicking this morning as a dac with mbp or samsung.
When I disconnected the type c cable (fiio) and was about to test with Tidal+ wifi I heard some clicks & hiss fading off.
Running Tidal+wifi has no clicks so I swapped it back to dac mode with samsung and it's clean.
Anyone experience the same issie and could it be usb power-ish issue when 1st connected to mbp?
Jan 26, 2024 at 6:24 AM Post #426 of 829
TempoTec V3-D
1800RMB (V3 1198RMB)
https://item.taobao.com/item.htm?id=763959168880
Jan 26, 2024 at 6:59 AM Post #427 of 829
does anyone here has v3 and Hiby R3 Gen 2 and if anyone has, can you please tell me how these two daps compare in terms of power, sound and OS functions like is the OS more stable with less bugs
The operating system of the R3 2 is the same but stable and error-free, it has some additional things like colors and volume control from the cable.
In real life, you don't notice the power difference like you do in the newspapers.
The sound is less dark, a little thinner and defined with a present bass, I personally like it better.
Jan 26, 2024 at 10:33 AM Post #428 of 829
Jan 27, 2024 at 1:42 PM Post #429 of 829
thx that's all i needed to know i'll probably order one
Jan 28, 2024 at 2:29 PM Post #433 of 829
Jan 28, 2024 at 3:10 PM Post #434 of 829
Just as bugged on some streams as the other HibyOS devices... (Had the same experience on my older R2) Certain streams would play 4 seconds, then buffer, another 4 sec, repeat... Even though the network connection is rock solid, and other streams work fine on the devices.
i tried it and all the streams that worked for me work fine haven't had such issues but many radios just don't load at all
Jan 28, 2024 at 3:11 PM Post #435 of 829
does the R3 II has preamp in the EQ the 12db slider cause v3 dosnt and it's very annoying
