kingoftown1
- Jun 19, 2011
Do you use a knife to remore the red ring and then paint it?
Yeah, the rings are just glued on, so I went under the edges with an X-acto knife (bent a couple blades doing this) to remove them. Then I just sanded and sprayed the rings with a flat black and finished it off with a spray sealant. Pretty easy in reality, and with the slight decrease in inner diameter of the rings after painting, I didn't even bother gluing them back on.
