xaval
- Jul 28, 2008
At the quality rate this thread is moving I can also senso Grado starting to sell drivers by the unit. Extra profit lol.
Anyone have pictures of their Gardo's with mini XLR or 3.5 mm detachable at the cups?
Mesquite....that would be wild just because its Mesquite!!!! ...."I have the latest in Mesquite headphones!", I thought that was a soft wood for some reason, I do not know wood at all....
Mmm Texas BBQ, I miss some good brisket...at any rate, I went ahead and ordered 3 feet of 4 braid silver wire from HGA, I've got a neutrik plug sitting here on the desk, and it's feeling neglected, also got sleeving and heat shrink, this will be my final mod for the SR-60s.
Majestic-- Thanks for the pics...good stuff, hey if your woodworking guy has a lathe you may be on to something....If I had spare shells and all I'd send them to ya so he could do the measurement thing...the high end Grado's are made of some hardwood I don't know why Mesquite wouldn't work....."Mesquite Bowls"- sounds like a basketball player....
STOP THE PRESSES!!!!!
I tried something I haven't seen yet with outstanding results...its not what you see its whats behind it...and its not the EVS thing...
I opened up the SR125's and did the following...
1) 7 holes
2) Dynamat on the driver button
3) Removed screen and button in one piece****
4) I cut some really thin foam I had lyin around (its like 1/32) to fit the inside dimension of the top
5) Foam first with the screen and button I took out in one piece behind the foam- button facing out toward camera
6) Closed it up with tape temporary and put bowls on.
7) Put on Radiohead KID A.....
8) Wet my pants!!!
You get the slam of the low end but no boom, no undefined thump its like the low end from my Ultrasones and the mids and hi's of the Grado sound. Its still technically open as the screen is there behind the foam so for whatever reason this
is pretty cool....It took Dynamat, and 7 holes to get them to sound like my modded 60's and this last thing was the icing. But hey I'm an old guy what do I know......LOL...check it out
