Nightslayer
- May 9, 2010
Your GS1000 shells look great, love the way you came from a simple circular piece to these.
Man, teaching yourself woodworking through sheer trial and error. A small suggestion, why not leave a sort of 'lip' sticking out over the outside part of the hole in the cup so that instead of having to bend the mesh and insert it in, you could simply cut out a circular piece and glue it neatly onto the lip?
