Dynamat Extreme mod V1 .
I only applied the Dynamat extreme mod V1 to one shell so I could compare my results with the un-modded shell .Some people compare there results from memory, though memory can be extremely subjective.I prefer using physical evidence to Gage my sense's .I would of also liked @ hand some scientific instrumentation to measure any change but I'm not a Audio engineer so used my ears without any secondary and conclusive evidence .
I thought I'd begin with having lots of dynamat, thus hopefully get a distinct change in sound that I could then use as a benchmark .
The Dynamat extreme mod V1 did not improve the sound .As you'd expect, covering most of the acoustic inner chamber in a energy/sound absorbing material dampened the vibrancy of the headphones & narrowed the sound stage .
I then began de-modding the Dynamat extreme modV1 ,removing a peace of Dynamat and then comparing the results with the non Dynamat shell .When I had removed all the Dynamat without noticing any improvement in audio quality, I then methodically re-applied some Dynamat but without the silver foil coating . But having still not heard any improvement I have now removed all the Dynamat from my SR80'i shell .
Conclusion:
It is possible that placing Dynamat or any other type of relatively high energy absorbing material may soak up some unwanted distortions . But when using such small amounts,like on the back of the driver for example, any change will most probably not be within human hearing range.
Though all these small changers can mount up to one Big change ( That's how we can save our natural environment for example ) .
Using Highly sensitive Instruments that can measure any subtle improvements in sound ,is the way to add up all these subtle audio improvements into Big Audio improvements ,
Obviously that is how science has been building upon measured evidence & evolving our technology ever since the first scientific instruments were created .We could not land Robots on planets like Mars that can be anywhere between 56 million to 400 million km apart by using subjective idea's .
And exactly the same evidenced based discipline applies to Audio engineering .
I think I'm going to have to do a little research into what methods headphone manufacturers actually use when developing their headphones .
