livewire
- Aug 13, 2010
FWJ FTW!
Lose the plastic.................they'll sound fantastic!
Awesome looking cans! <<2 thumbzup>>
My MCA Coco MS1i still have their sparkle and then some.
No mods to the drivers, stock cables.
You remove the teflon sheathing first with a wire stripper.
Basically it is a cutter / plier designed for this purpose.
Strip it back to the length required, usually about an eigth of an inch.
You then "tin" (pre-prep with solder) the now bare wire-end(s) with the soldering iron
before actually soldering it to the circuit or driver solder / connection pad.
Run a google search for wire soldering techniques (or preparation & procedures)
There is a ton of info about this topic on them interwebz.
