Im thinking i really prefer the weaved style mesh, seems to look more retro, and not as aggressive as the others. So i may try bowls if she says they are uncomfortable. So final verdict, should i open the vent holes or no? Seems like mixed responses on that.
If you intend woodying them - don't open the vents. If you don't (ie if you are going to leave the cups and base as stock plastic), then opening vents will give you a little more bass. If you do vent, start with no more than two holes in each cup, and work your way up as needed. It also pays to vent evenly (ie space the holes symmetrically).
Ultimately it's your call.
