wje
Unmodified = Not worth listening to.
Btw, is it possible for me to change the cable because the thick cables are bothering me a bit >< what other mods do you guys recommend? Thanks!
Yes, you could change out the cable. Lots of people either make their own by procuring good wire and connectors such as the Neutrik 1/4" connector. Also, you'll see people who make cables for other people out of silver wire - which can change the sound signature a bit.
I'm kind of with the same thought as you. I have 2 pair of Grado 225s. One has the thicker cable and the other has the older style - thinner cable with less conductors. When I take the headphones to work with the thicker cable, it tends to get a bit unruly in my desk area as I listen to the 'phones. Meanwhile, the thinner cable is a little more relaxed and doesn't get in the way as often.
