- Jan 30, 2011
Ah - but add the Senn 414 pads though ....... and then you'd really look like a bumblebee
The Steelers black and yinzer yeller look is god awful, if that's what puts them in god tier, just sayin.
Best custom headband ever. Made by a man on this forum. These are NOT mine but the guy posted pictures and I saved them because they were god tier.
I like the padding on the head band.
Sorry, just picked up my pair of SR60 yesterday, having some issues with the comfort of the pads and the quarter modding looks pretty helpful to the sound as well. How should I go about doing that? Thanks!
Are you sure that the headband might not be causing some of your issues, too? The headband can be a bit tight on some people. Usually, taking your hands and slowly spreading open the band so it isn't as tight resolves the issue. Work slowly - just small movements. You might have to do it a few times to get the right level of comfort for your head. Different pads will change the feel a bit - but, if that band is too tight for your head, it's hard to just use different pads to handle that issue when the metal needs to be adjusted.
Ok thanks will take note
Btw, is it possible for me to change the cable because the thick cables are bothering me a bit >< what other mods do you guys recommend? Thanks!
Could some people please check out my thread and let me know what you think? It's SR60 mod related.
http://www.head-fi.org/t/568978/my-sr60i-mod
