Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
- Sep 28, 2003
Here's a practical example of a bridged output audio amp:
I have a Bryston 2B-LP stereo power amp.
60 Watts/ch @ 8 Ohms
100 Watts/ch @ 4 Ohms
Manufacturer does not recommend using this amp to drive 2 Ohm loads.
A few years ago I needed to press it into service to drive the centre channel in my home theatre system.
There is a stereo/mono switch on the rear of the amp.
This bridges the two channels together, so now I have 200 Watts @ 8 Ohms.
Approx. twice as much voltage, approx. twice as much current into 8 Ohms and twice the slew rate! And approx. 4 times as much power! Yippee!
Sure. But that's only because all you had was a bridgeable 60 watt amp. My point is that the same thing could have been accomplished with a non-bridged 200 watt amp.
Arguably I needed twice the slew rate as I now have twice the output voltage!
Just because you're outputting twice the voltage doesn't mean you need twice the slew rate. The slew rate of each amplifier channel may be very high, so that they could easily double (or more) their voltage swing without any slew limiting. The same topology can be used to produce amplifiers with a wide range of power outputs. You just need to change the gain, supply voltage, the number of output devices and the amount of heat sinking.
And bridging two amplifier channels doesn't change the slew rate of the individual amplifier channels. They still have the same slew rate they did before bridging. You only get the doubling of voltage because one is driven with a signal of opposite polarity and the differential voltage between the outputs has doubled.
The downside is the mono (i.e. bridged) configuration is not recommended for driving 4 Ohm loads. Yes, there's a downside.
That's only because the individual amplifier channels wouldn't be able to dissipate that much power. That's a function of design choice, not bridging.
So the "twice as much voltage, current and slew rate, and four times as much power" statement is true, but is rather misleading too.
Yeah, but as I said, compared to what? A non-bridged amp can also deliver twice the voltage/current of a bridged amp, twice the slew rate, and four times as much power. Sure, if all you have is a particular amp, that's one thing. But I'm talking about what's possible in the marketplace.
Furthermore, this amp (whether used in stereo or as a mono bloc) has balanced inputs (i.e. differential inputs) so, assuming it's receiving a signal from a balanced output pre-amp, and you are using a balanced interconnect, the input will reject common mode noise (within a limited bandwidth, of course).
BTW, the input stage converts the signal into a Single Ended signal, which then drives the power amp stage.
Other amps may have different configurations, YMMV.
Yeah, it's pretty common to have a balanced input, do everything in between single ended, and then balace the output, if you're talkingbabout line level gear, or just continue the output single-ended in the case of headphones or loudspeakers.
se
