music_man
- Jun 6, 2005
Thanks. I hope I like the AG Axios. I wouldn't want to return it because without the CU here as well I cannot really hear the differences. I would kind of think the Sony/Kimber is pretty close to the Axios CU. Apparently not so. I wanted to point out something. Kimber say all Axios have "16 conductors". Not true really. They have 16 pairs of FEP sheaths each containing "10" conductors in the true sense of the term. So therefore I would suppose, properly stated they have 160x32AWG "conductors". Honestly that in itself does not translate into any sound regardless. Just setting forth the terminology as I know it. It has no bearing on the sound, the amount of conductors.
Do not buy homemade cables on ebay or amazon made in china. If you must, just get the sony/Kimber. Those homemade Chinese cables who knows what you get. If it is $25 okay try it. Ones for $400 I would not touch that. The sony/Kimber seems vastly overpriced at $250+. Whereas I did not sneeze at the AG Axios being about 4 grand. Indeed like a jeep vs. a Range Rover. You get what you pay for and I know this so I do not bat an eye. It is the only sound of the Z1R I plan to know so I hope I like it. I am pretty flexible. I have equipment with sound signatures all over the place. I just hope the AG does not create some "problem" such as shrill treble. Returning it does nothing because without both at the same time I know none the better. AG is not more money because it is "better". It is simply a more expensive material and harder to work with as well. I wanted to accentuate the treble as the bass is plentiful so I am thinking I shall be happy with my decision. Currently burning in. I will do so for 500 hours. So no comments from me for 3 weeks. However it is already evident these are high end headphones by any means. Opening them I couldn't believe my eyes with Grado's packaging in mind LOL.
