MrWalkman
Ok, it's here:
DMP-WM1 II
Features:
- sound signature resembling the one of the DMP-Z1
- native DSD playback over the 3.5 mm output (available only for the 4.4 mm balanced port on the stock firmware)
- DSEE AI (present on DMP-Z1)
- progressive JPEG and interlaced PNG album covers are supported
- hardware accelerated rendition of the UI
Differences between the sound of DMP-WM1 and DMP-WM1 II are a more full, smooth, and natural sound. The
soundstage is a bit less wide at first hearing, but it's taller, creating a more 3D effect. The texture of the bass can
also be heard more easily. I'll leave the rest for you to find out
Installation:
1. Install DMP-WM1 MK2, and then close the installer
2. After that, install DMP-WM1_MK2_Ext_Tuning
3. Restart the player
To revert to the stock firmware:
1. Install StockRevert (DMP-WM1 MK2), and then close the installer
2. After that, install StockRevert_Ext_Tuning
When installing DMP-WM1 MK2 or when installing StockRevert (DMP-WM1 MK2),
the player should restart and go into update mode. The update bar should
fill up to the end. Otherwise, you won't be able to install the external
tunings.
The firmware is available here.
Feel free to give it a try and share your thoughts. And most importantly, enjoy!
Happiness comes suddenly! Thank you friend for all the work done!
in a hurry to try as soon as possible.
By the way, if you have DMP-WM1 installed, you will first need to use the StockRevert of DMP-WM1. Otherwise, you won't be able to install DMP-WM1 II.
