Feb 16, 2023 at 6:07 PM Post #7,546 of 9,216
Would like to let MrWalkman know that the RMT-NWS10B works just as well on the A55 with his CFW as it does on a stock player. I think you can edit the FAQ on your site which mentions that only the RMT-NWS20 works. And many thanks for this CFW of course, the WM1Z tuning is super pleasing.
Feb 21, 2023 at 7:53 AM Post #7,547 of 9,216
which region do you like best? does dampened mean the sound is muffled?
Feb 21, 2023 at 8:08 AM Post #7,548 of 9,216
All the regions have their own place as they serve different tastes. But the most popular around here is probably J and MX3. Dampened means slightly subdued treble or peakiness or harshness and may not necessarily mean muffled or boomy in that sense. A good balanced region to start with would be J.
Feb 27, 2023 at 9:03 AM Post #7,551 of 9,216
Got the wm1a, put the walkmanOne on it, wm1z tuning, no clue which region yet.
sounds absolutely phenomenal. good chance this dap will stay forever :)
The default region is J on Walkman one.
Feb 27, 2023 at 10:57 AM Post #7,553 of 9,216
interesting, thanks, I'll have to see how U and MX3 stack up, but won't dive too deep into it because those seem to be top 3 fav favorites
Or J3 on the latest 1A/1Z only test release
Feb 27, 2023 at 9:01 PM Post #7,555 of 9,216
Settled on mx3, wm1z, dac initialization off, high gain, plus mode v2 (not going to lie no clue what plus mode does)
Plus v2 mode refines the sound a little and removes some unused background processes in the Walkman that in turn save battery life. But it also cripples the Bluetooth DAC mode. So if you don’t use Bluetooth DAC the Plus v2 mode would be the ideal choice.
Feb 28, 2023 at 1:57 AM Post #7,556 of 9,216
Esto es algo en lo que ha trabajado recientemente. Si quiere, puede que se incluya de alguna forma en el firmware del Walkman One, ya veremos. Puedo hacer algunas de mis propias modificaciones similares en el futuro.
Me pondré en contacto con los problemas del bucle de arranque más tarde hoy.
Oye, ¿has arreglado una forma de arreglar el bootloop?
Feb 28, 2023 at 3:45 AM Post #7,558 of 9,216
