Jan 13, 2023 at 11:09 AM Post #7,443 of 9,215
will they ship it to anywhere in the world?
You hand your dap in to the local Sony center and they perform the replacement as I understand it. Or if you are in UK you can send it to Nayparm
Jan 13, 2023 at 12:47 PM Post #7,445 of 9,215
Jan 13, 2023 at 12:55 PM Post #7,446 of 9,215
Jan 13, 2023 at 2:48 PM Post #7,448 of 9,215
Thank you for posting this combination. I just picked up a used WM1Z and this combination of settings sounds spectacular!
I use the same except using alternative dac mode
Jan 14, 2023 at 12:04 AM Post #7,451 of 9,215
Hey does anyone know if a Sony dap purchased in Australia is subject to a volume limiter like in EU? Thanks
AFAIK, only EU has the volume limiter for Walkmans. In any case, this can be easily disabled by changing your region using Walkman one or the region changer tool.
Jan 14, 2023 at 7:36 AM Post #7,453 of 9,215
As @aceedburn said only EU models have the vol limited. However to satisfy yourself you could check with the SonyNWDestTool
Jan 16, 2023 at 12:44 PM Post #7,454 of 9,215
I have ZX300 incoming and would like to install Walkman One firmware. Would someone kindly post a link to step wise instructions (if they are available that is)?
I’m rather anxious about doing this sort of thing, so an “idiots guide” is most welcome. Thanks
Jan 16, 2023 at 1:11 PM Post #7,455 of 9,215
Just follow the instructions that come together with the fw
