Hummm, thanks for your help, but I was able to install neutral/warm and 1Z…
There is a bug in Bright software. It do not permit to recognize my 1A in mass storage, that’s the issue. It always ask me to connect the device. Mass storage is ON on 1A.
I tried several times.
If I change for 1Z or neutral/warm it installed directly.
First, I wanted to install bright, it was not possible, so I installed neutral/warm with no issues.
After tests, I tried again to install bright, same issue.
So I installed 1Z, it works directly.
Each time I got the same issue.
I always reboot and verify in settings.txt if everything is good.
@nc8000 : regarding the FW that I called called J123, I got it here : Post #6,731 of 7,365
Regards
Regards
