# Instructions regarding the installation and reverting to stock procedures
## First, a little extra info!
- The additional settings file can be found in the internal memory of your player,
in a folder named "CFW". To access the internal memory of your player, connect the
player to your computer using the USB cable, and make sure that the Mass Storage mode
on your player is enabled.
- The boot log file can be found in the same folder.
## Installation:
1. Connect the player to your computer using the USB cable, and make sure that
the Mass Storage mode is enabled;
2. Run "Walkman_One_WM1_(19_09).exe" from the "Installation" folder, and follow the on-screen instructions;
- The player should restart into the update mode, and the update bar on the player's
screen should fill up to the end before the player restarts again.
- If the update bar on the player's screen does not reach the end, make sure that
you are on the stock firmware before trying to install this! Check if you have
another custom firmware already installed in the Unit Information menu in the
player's menu.
- When first starting up after installing the firmware, your player will reboot once,
automatically, during the boot animation. This is normal.
3. Proceed to install the WM1Z external tuning (located in the same "Installation" folder), or choose
another sound signature in the settings file, restart the player, and then install the corresponding tuning.
- To confirm that a tuning was successfully applied, you can check the boot log file
or the Unit Information menu on your player - if the tuning would not be installed,
you would see a message in this menu, saying "External tuning not applied!".
## Reverting to the stock firmware
1. Connect the player to your computer with the USB cable, and enable the Mass Storage mode
on your player;
2. Run the "1_StockRevert_Walkman_One_WM1.exe" installer from the StockRevert folder;
- The device should restart into the update mode, and the update bar on the player's screen
should fill up to the end.
- To confirm that the StockRevert package ran successully, you can check the Unit Information
menu on your player - you should no longer see "Firmware mod by MrWalkman".
- If you still had the "CFW" folder in the internal storage before running the StockRevert
package, along with the "boot_log.txt" file in it, you will see additional info related to the
reverting process in the log file.
- After successfully running the StockRevert package, you can delete or keep the "CFW" folder,
it's your choice.
3. Run the "2_NW-WM1_V3.02.exe" installer located in the same "StockRevert" folder;
- If the StockRevert package was successfully applied at step 2, then the player should again
restart into the update mode, and the update bar on the player's screen should fill up to the end.
# If everything worked out as instructed above, you're now on the stock firmware. You can install
another custom firmware, or any other official firmware updates.
